jeeeze this h23 is a big prob
so im one of the many plp with a prob with there prelude with a fluxiating idle..ive taken it to 3 shops here where i live..one said it eather needs a new computer or tpi sensor..the onther one said idk what it is..another told me that im gunna have to take it to honda..what all ive done is..2 new tpi's..new t.b gasket..3 new ecu's...3 new idle air controll valves...i bleed the coolant..checked for vaccume leaks..i kno it could be alot of things..anyone gone through this?
wow dude let me get one of those brand new IACVs....lol
What do you mean by tpi?
Throttle body?
Throttle position sensor?
You most likely need to tighten down the wax screw on the back of the FITV, which is under the throttle body, take the screws on the rear loose, take that gold metal plate off, and then screw the large wax ring.
Throttle body?
Guest
Posts: n/a
uve been going around the problem, just take out the FITV and clean it..disassemble it like you would a firearm, clean it with penetrating oil or brake cleaner, and put it back together nice and well..i just did this yesterday..the car had jumping idle everywhere..30 mins of work and the problem was gone. bet u wasted a lot of money on those parts.
ps. whats a tpi? tps?
if i hadnt forgot to buy batteries for my digicam i would have taken pics of the process yesterday, since i see so many people with this problem on here.
lol ya sorry i did that also..i took that out..cleaned it with carb cleaner..still the same thing..i did that when i had the t.b off when i was putting the new gasket on it..and yes sorry i ment tps sensor..sorry
take some carb cleaner and spray it around your lines on top and underneath the intake mani...its messy but your engine will rev up if it pulls it in....when you done go wash your engine down at the car wash....has worked many times on friends cars while in college.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericstambaugh07 »</TD></TR><TR><TD CLASS="quote">ur talkin about the white plastic part in there arent u? if u are i tightend that all the way down</TD></TR></TABLE>
well thats too much....but at least that eliminates a problem.
ya ive tryed so much..i called another performance shop here..and they told me they had a prelude with the same problem awhile ago..and they had to send it to honda..so tomm..ive got an appt. with honda.
scsparts
Sep 12, 2003 02:49 PM
