head bolts h23
Old Feb 19, 2007 | 01:58 PM
IAluder95's Avatar
Default head bolts h23
how much tq do you use to loosen up the head bolts on h23?
Old Feb 19, 2007 | 02:47 PM
EKHWhat's Avatar
However much it takes.
You only have to worry about the order in which you loosen them, the order in which you tighten them, and how tight you tighten them when you put them back on.
Three passes. 29 on the first pass, 51 on the second, and 79 on the third pass. Make sure you do all of them opposite from each other. Like do the bottom right followed by the top left, bottom left then top right, etc.
Old Feb 19, 2007 | 04:14 PM
95greenlude's Avatar
Default Re: (EKHWhat)
i broke an Impact rated socket trying to get one of my head bolts off....now the bolt is stripped all to hell.
go get an 14mm impact rated socket 1/2" with a 26" breaker bar should get them loose
Old Feb 19, 2007 | 04:16 PM
mgags7's Avatar
Whenever you're dealing with something that tight:
Use only 6 point sockets
Use half-inch drive or larger
Use as little extension as possible
Wear eye protection
Jared, go to sears and get the craftsman nut extractors, that thing will get it off.
Old Feb 19, 2007 | 04:23 PM
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Whenever you're dealing with something that tight:
Wear eye protection
Jared, go to sears and get the craftsman nut extractors, that thing will get it off.</TD></TR></TABLE>
im headed to sears tonight to get one....
n8dogg
Feb 20, 2006 01:24 PM
cardigit
May 24, 2005 06:54 PM
Nikoli
Feb 5, 2004 09:55 PM
AndyD
Jan 11, 2003 07:17 AM
DLB1994
Mar 15, 2002 10:26 AM
