replacing turn signal bulbs on a 2000 Accord
Old Feb 19, 2007 | 01:48 PM
shankbear's Avatar
Default 2000 Accord
How do you change the front signal lamps on a 2000 Accord? Does it require removing the bumper, fender, grille?
Old Feb 19, 2007 | 02:04 PM
TheMuffinMan's Avatar
He knows where you live!
I'm guessing you just mean the turn signals? from the looks of it I'd say it's somewhat similar to the 94-97 which requires you to remove the bumper to take out the headlights as they're all one piece. If it's just the bulb you're looking to change out then it should be reachable from inside the engine bay
Old Feb 19, 2007 | 02:09 PM
shankbear's Avatar
Default Re: (TheMuffinMan)
thnx MM. That was what I was afraid of. That sux. What a pain.
Old Feb 19, 2007 | 02:24 PM
Well i will tell you, for my car's headlights I can take off the bumper in about 5 minutes now haha, so it's really not too terrible
Old Feb 19, 2007 | 02:38 PM
skingfreak's Avatar
there is no need to remove the bumber, infact it wont help you. you have to undo some of screws holding the fender well lining, and your golden.
Old Feb 19, 2007 | 07:23 PM
shankbear's Avatar
Default Re: (skingfreak)
I have changed the headlight without a problem. It is the turn signal that is the pain. If I can just undo the lining of the wheelwell that should do it eh? This is getting me....a 1.50 bulb and a car dealer wants 400 to change it. crap a monkey.
Old Feb 19, 2007 | 08:02 PM
philadd's Avatar
Default Re: (shankbear)
$400?? Tell me you forgot the decimal point before to 2 zeros. Hell, if you meant $400, then they must be thinking you want to replace the headlight assemblies, as there's no way they would charge you that to replace ANY bulb.
Like skingfreak said, just pull back part of the fender lining and stick your arm in there.
xxkevo
Jul 14, 2006 04:28 AM
BlaqK20
Oct 8, 2004 05:12 PM
JiGzAcura
Aug 30, 2004 12:00 PM
Turbo Powa
Mar 26, 2002 01:16 PM
