F23 Build
UPDATE!!!! dyno vid and sheet up on page 6!!!!!
I just thought i had to share my story so far on how the project is going
read if you want (the stock f23 accord motor SOHC 4 cyl)
i have a custom turbo kit running about 7-8 psi on a stock motor, with an aem ems, pushing 250 or so to the wheel. I ran the car up at Brainerd on the road race track, back in April of '05 back then it wasnt as powerful and tuned with a SAFCII, and i blew the motor, too much heat from constant boost (kind of a dumb idea on my part but oh well).
So i had the motor ripped apart, turns out i cracked a couple of pistons and rings. i had decided to get it sleeved and built, well the long and short of it is, a shop in CA took over 8 months before we realized it was taking to long, so we had it shipped back, and out to Nebraska, this guy never answered his phone, the shop had his buddy pick it up, and ended up going to jail, which they locked up my motor, because he owed money or something. So the shop i go through bought a new block. (ticking on about 13-14 months now), found a local shop in MN to do it, he bored it halfway, and then had to close, then i found Dick Burns in Wyzata. i found out that block was cracked, ordered a new one, and now after 20 some months i have it sleeved and a polished crank.
The total is four blocks (the one i blew, the one thats cracked, the one thats sleeved, and the extra used one in my car) and four shops in 20 some months to sleeve a block!
The block is now decked, sleeved, machined, and only rough honed so far.... the other shop i go to will be doing the fine honing.
Enough talk heres the pictures of before and after:
BEFORE:
AFTER:
And the plan of the build:
Darton ductile iron replacement sleeves
Polished crank
Crower Rods
Custom JE pistons (9:1)
New piston rings (obviously)
ferrea valves
JG engine dynamics valve springs, retainers
ARP head studs
New bearings, gaskets, oil pump, water pump etc. etc.
Injectors (probably 770+)
Heres the bottom end assembled:
The head still needs to be picked up so i didn't get any pictures of that yet, but hopefully soon, within this month here i should have dyno video, and numbers!
had trouble with the valve springs, had to return them, and order new ones, but they came in today and heres some pictures:
awaiting assembly, install, and tuning!
!!!!!Update!!!!!!
Motor is assembled and going in the car OCT 4th!!!!! woot woot!
Modified by hotaccord243 at 4:47 PM 7/28/2007
Modified by hotaccord243 at 4:49 PM 7/28/2007
Modified by hotaccord243 at 2:41 AM 9/20/2007
Modified by hotaccord243 at 8:18 PM 5/22/2008
Modified by hotaccord243 at 10:13 PM 9/22/2008
Modified by hotaccord243 at 10:15 PM 9/22/2008
BEFORE:
AFTER:
Polished crank
Crower Rods
ferrea valves
ARP head studs
!!!!!Update!!!!!!
I have the exact same build up as you. The only difference is I went with Benson Sleeves. I had it running on the AFC HACK for a month before installing the AEM EMS. I'm having issues with EMS right now. Hopefully in a month or so I'll have it back on the road.
What trans are you running with the build motor?
If you're interested here is my build up. http://www.everything-honda.co...=3679
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oodie »</TD></TR><TR><TD CLASS="quote">nice what numbers are you looking for</TD></TR></TABLE>
well right now the numbers are what we feel is comfortable with the turbo, the turbo maxes out at 480, so safely im shooting for 400 or more it depends on how the tuning on the dyno goes but roughly 400whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aci78 »</TD></TR><TR><TD CLASS="quote">Sorry about your luck- way to be persistent! I'm planning on doing same thing, so keep us posted, please-</TD></TR></TABLE>
i will definately try to update as much as i can!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinker504 »</TD></TR><TR><TD CLASS="quote">I have the exact same build up as you. The only difference is I went with Benson Sleeves. I had it running on the AFC HACK for a month before installing the AEM EMS. I'm having issues with EMS right now. Hopefully in a month or so I'll have it back on the road.
also stinker, you and B, have been the motivation behind the project i have talked to you and him pretty often about questions and stuff, i believe i have read every page of yours and B's builds, thats what got me going on this thanks!
also the trans is the stock f23 5spd trans right now with an act stage 2 race/street clutch probably eventually rebuild it with an lsd but thats after i pay all this off hahaha
If you have a thread on your problem with the ems i know a little bit about i could try to help, good luck with that im loving watching you and B work with your accords its awesome knowing that there are at least a couple willing to go this route and go on a limb haha!
well at least its that easy to just send it in and get it back hopefully good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandoEX »</TD></TR><TR><TD CLASS="quote">The build sounds awesome man!!! Hopefully I can see your car in action if you bring it up to Brainerd
Do you plan on drag racing it at all?</TD></TR></TABLE>
i do plan on bringing it up to brainerd for road racing and also dragging this season
thanks for the comments guys
Do you plan on drag racing it at all?</TD></TR></TABLE>i do plan on bringing it up to brainerd for road racing and also dragging this season
thanks man, i'm hoping so, and also hoping to post numbers and videos soon too, but as you can tell, nothings been fast, but well see
i think i seen this thread before? or was that another dude with the same problem sorta like got a bunch of motors and someone went to jail
nvm good luck
edit: thats WAS you damn even more good luck lol
nvm good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gianinline »</TD></TR><TR><TD CLASS="quote">oh.... gotta be on the look for this thread. I'm sorry to hear about those 20 months of waiting... must have been very frustrating.</TD></TR></TABLE>
for real i give up ona dump after 20 minutes, damn mexican food
j/k
j/k
Final update before dyno vid, dyno graph and pics!!!
motor is going in OCT 4th and 5th!!!!!
will post vid, graph and etc. immediately after!
well heres some pictures of the first day of work, today, the motor is being assembled the rest of the way, then going in and tuned
well heres some more pictures!!!!
motors coming out-
motors out-
dissassembly for misc parts-
finally what you've been waiting for is pictures of the head!---
Today- built motor in and getting tuned more info to come very soon!
motors coming out-
motors out-
Hey Hando, thanks i appreciate it, im glad to see it come together also, i am tuning it out in Sioux Falls with the AEM, right now for break in period we decided to go with a tune that is at the 250 whp, and then open it up after the break in period, in a week or so.....
as far as the valves, the ferrera valves did not work out, so actually they are SI valves i believe and they only ran a couple hundred so not too bad at all
heres some more pictures for you guys-------
the head attached
assembly---
tranny getting cleaned up-
motor going in-
on the dyno-
the head attached
assembly---
motor going in-
on the dyno-
I'm running a bone stock f23a7 in my CRX right now, boost will be the next step... your dyno run should be good inspiration, not enough F people out there
Nice and Good man
I just can believe he background of your story in that case I personally don't do it. To much problems and little pacience.
But congratulations and I will be looking forward to this project Fseries
