Daily Driver Oil
if you want to know a lot about oil try http://bobistheoilguy.com/
I have been using mobil1 5w-30 for some time now, works great as far as I have seen
As long as the API Service Grade meets the manufacturer's requirements and you change it as required, any oil will suffice. If you want to spend more on synthetic or something, that is of course up to you. The main thing is to change it as required.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude252 »</TD></TR><TR><TD CLASS="quote">BUMP</TD></TR></TABLE> what was that for?
I run Royal Purple 5w30
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redtop22 »</TD></TR><TR><TD CLASS="quote"> what was that for?</TD></TR></TABLE>
I know, he keeps doing it in different threads... :? I don't know why..
Sorry for not being on topic...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">
same here
</TD></TR></TABLE>same here
he's done this in my last two topics. Is there any real reason for this?
Castrol regular 5w 30 don't use syntec it doesn't do anything thats noticeable and is more expensive. Also for the people that think u can't go back to regular oil after using syntec its a myth. Always use Honda oem oil filters people say use k&n and what not but there is certain stuff you only replace with oem honda stuff. Like the oil filter, Main bearings, rod bearings, water pump, timing belt, oil pump....Etc.
george34
24
Sep 10, 2006 06:51 PM
