toda valve springs and retainers with skunk2 pro 2's>?
Old Feb 19, 2007 | 07:53 AM
Reza^'s Avatar
Default toda valve springs and retainers with skunk2 pro 2's>?
wondering if you guys thought these toda springs and retainers would be fine to use with the skunk2 pro2's?
Old Feb 19, 2007 | 10:55 AM
b16nonoy's Avatar
Default Re: toda valve springs and retainers with skunk2 pro 2's>? (.:Reza:.)
they will..but over priced...
Old Feb 19, 2007 | 11:42 AM
pomansouth01's Avatar
Ginger Kid
and chances are that they crush your valve seals
Old Feb 19, 2007 | 12:13 PM
Reza^'s Avatar
Default Re: (pomansouth01)
how would they crush them? what do you recommend
Old Feb 19, 2007 | 12:46 PM
GUILOTINE's Avatar
Kill Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 &raquo;</TD></TR><TR><TD CLASS="quote">and chances are that they crush your valve seals</TD></TR></TABLE>
how do you figure?
Old Feb 19, 2007 | 02:37 PM
Combustion Contraption's Avatar
Default Re: (GUILOTINE)
he's probably referring to the ret. design.
I havent looked at a TODA retainer, but if its the same height as a OEM, you would run into problems with high lift cams.
Old Feb 19, 2007 | 02:59 PM
GUILOTINE's Avatar
Kill Gil
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">he's probably referring to the ret. design.
I havent looked at a TODA retainer, but if its the same height as a OEM, you would run into problems with high lift cams.</TD></TR></TABLE>
I doubt that, Toda valve train is designed to handle lifts of 12.5mm+ (Toda C's) without any problems.
Old Feb 19, 2007 | 05:35 PM
I doubt it as well, but i think thats what he was insinuating.
Old Feb 26, 2007 | 08:00 PM
Ginger Kid
good job mr contraption, that is exactly what I was meaning by saying these words. I however did not consider that the toda c's are in the same boat as skunk pro 2's. I have skunk pro2's and omnipower springs and retainers that crush my valve seals...
jt-sport
Sep 12, 2007 09:16 AM
jt-sport
Jun 14, 2006 05:23 PM
Renegade
Aug 4, 2004 12:40 PM
Slow96RedEk
Jan 15, 2004 04:43 PM
P1mpSlap
May 27, 2003 07:55 PM
