BLAQMANS BLOWOUT BONANZA! cusco, hks, blox, apexi, clifford, tokigo, ha sport, hella, CTR, JDM
Old Feb 18, 2007 | 08:48 PM
blaqman's Avatar
Default BLAQMANS BLOWOUT BONANZA! cusco, hks, blox, apexi, clifford, tokigo, ha sport, hella, CTR, JDM
Blaqmans Blowout Bonanza!
1) I have the following parts for sale…please read everything closely. I am in the LA 323 area. I can meet you within a reasonable distance…for a reasonable amount. For instance I will NOT drive to Orange County to sell you a $20.00 part. But I will for a 100.00 part get it….
2) As of now I am willing to ship smaller parts.
3) If you don’t like my prices get out of my thread. I don’t need the money; I just would like to sell these parts.
4) Prices are OBO
5) Email me at fast_srunner@sbcglobal.net for faster response.
6) AIM: master of apex
7) If you are interested make sure to leave your phone number.
8) Open to trades, JDM wheels, rare ef parts, d-series turbo kit, name brand seats, newer alpine head unit or in dash, 5 lug suspension
Electronics and security
•Old school HKS egc and GCC (best offer over $450. Maaaaad JDm YO!
•88 91 jdm sir gauge cluster $150.00 with plugs
•Clifford avant guard 5 (called worlds best alarm by popular car audio mag) anti carjacking, code hopping, extreme range 1 mle I think, alarm alone is $400+ window modules are like $150.00 each...and I am including 2 modules that will controll 4 windows, or 2 windows and a sunroof. Bottom line...if you buy this alarm...they will have to tow your car. Asking $500.00 for everything. Also GPS compatible so even if they do tow it...you will get a text message showing your alarm has been set off..then you can call it in and guess what....you get your car back in one piece
•Vafc 2 Like new 175.00
•omori gauges (oil pressure 175.00 obo)
Suspension/ brakes
•Tokigo illumina's 5 way adjustable READ CLOSELY (these are for a 90 93 integra....yes they will physically fit a 88 91 civic...but you cannot DUMP the car cause you will have LITTLE TO NO SUSPENSION travel with these shocks on 88 91 civic. They have about 12,000 miles on them and yes they are complete. 175.00
•88-91 Civic SI Spindle-$100 with brakes
•90-93 Integra E brake cable plus clutch cable-$60
•88-91 Civic/90-93 Integra JDM Cusco front lower tie bar-$180
Interior
•Jdm center armrest (BLUE) also have additional base for it. 160.00 you know how rare they are to find in black....try finding one in blue. You wont!
•90 93 sparco brackets...one slider....$200.00....no I dont have the other slider.
Misc
•Hella HID ballasts-$130 (all you need are bulbs)-$130
•Corolla GTS AE86 oil cooler (for your turbo project)-$50
•Civic Dx engine harness-$100 (will not work on SI) resistor box not included
•SI resister box-$30
•90-93 Integra lip-$30
•88 91 si shift linkage (stock) $70
•90-93 integ shift linkage $100
B series engine stock stuff
•94 gsr long block 95k miles....900.00 obo
•JDM Buddy club cam gears-$110
•Clear plug distributor, B series-$100
•GSR inner/outer valve springs-$70
•GSR rebuild parts:
-oil pump, water pump, tensioner (2), timing belt, head gasket, upper radiator hose, lower radiator hose, rear main seal (2), trailing arm bushings (2), oil pan bolt, oil pan gasket (2), intake manifold gasket-$300 for all! No I will not sell anything separately.
•B series starter $40 each
•Obd 0 B series Dizzy clear plug $125.00
•GSR throttle body w/ sensors (2)-$65 each3)90 93 integra shift linkage $100
•90 93 integ engine harness $125.00
•90 91 integ a/c compressor $50.
•civic type R cams $400.00 (you know what these are)
•gsr valve cover (stripped ready to paint $40.00
•90-93 Integra motor mounts-$100
•Stock Integra clutch GSR-$25
•94 gsr exhaust manifold and itr b pipe 150.00
•90-93 axles-$80
•90-93 ˝ shaft-$50
•90-93 rear bracket-$40
Performance parts
-fluidyne ef radiator $170
•blox intake manifold for gsr (no it will not fit B16 or type Arrrrrrr!) with fuel rail, 75mm throttle body, pressure gauge, all sensors, and type r throttle cable. $500.00 obo (low ballers will be shot!)
•88 91 civic ha sport mounts 200.00 obo. They are not the billet ones
•arp head studs for gsr (all studs are there missing a few nuts and bolts) torqued once 60.00
•Clutchnet 6 puck clutch and pressure plate. I believe this will fit all trannys EXCEPT the YS1. If I am wrong then it will definitely fit 90 91 trannys.
bump for t3h blaqman....needy monies for boozies
Old Feb 18, 2007 | 09:29 PM
blaqman's Avatar
Default Re: BLAQMANS BLOWOUT BONANZA! cusco, hks, blox, apexi, clifford, tokigo, ha sport, hella, CTR, JDM
ttt
Old Feb 19, 2007 | 07:36 AM
blaqman's Avatar
arrgh
Old Feb 19, 2007 | 08:42 AM
blaqman's Avatar
ttt
Old Feb 19, 2007 | 01:58 PM
JDMCARBOY's Avatar
bump!
Old Feb 19, 2007 | 08:50 PM
blaqman's Avatar
Default Re: (JDMCARBOY)
good lookin out homey.
Old Feb 19, 2007 | 10:52 PM
blaqman's Avatar
Default Re: (blaqman)
ttt
Old Feb 23, 2007 | 05:23 PM
blaqman's Avatar
up up up
madjdmek9
May 9, 2008 12:24 PM
blaqman
Mar 23, 2007 12:07 PM
BarracksSi
Mar 6, 2006 05:57 PM
civcexcoupeblack
Jan 29, 2003 07:31 PM
