starting problem 2000 accord
170,000 miles, jumped started it once then died out. car sat for 2wks then it started right away, drove it 2 miles then stoped to put gas then didnt want to
start tried to jump it again but just turns but does not start.
man i have been havin about the same problem, i was driven one day it just shuts off got it started did it again. Got the fuel system checked and cleaned but not it i burnt up my distribitor put another home on thought i was home free but wasn't so if anyone has a suggestion let me know pleace thank you
That's a common problem with accords. Change out the main relay and both your problem will go away. The main relay is located under the steering column and cost about 40-50 from your local dealer. Item 10, Location: http://www.hondapartscheap.com...ity=0
RA12825
Jan 20, 2013 11:16 AM
lovinlife
May 4, 2010 01:24 AM
Flexer
Jun 22, 2008 12:59 PM
