LS/VTEC Dyno
Old Feb 18, 2007 | 07:34 PM
NA-PR-CRX's Avatar
Default LS/VTEC Dyno
Before: 81 x 89mm, civic type r pistons, toda b cams, toda valve springs-ret, b16a head- type r I/M, 65mm TB, stock injectors, obd2 spoon ecu with field, dc sports 2.5' header, 2 1/2 exhaust to universal cheap muffler, 3' short ram with bpi:
After: 81 x 89mm, civic type r pistons, toda b cams, toda valve springs-ret, b16a head- type r I/M, 65mm TB, rc 370's, p28 ecu tuned with crome, jge header, 2 1/2 exhaust with cut out and oem type r muffler:
Bigger difference where in the midrange and TQ, at 6k like 20hp more and 7k- 13-14hp,
and tq at 6k- about 15 ft lbs, at 7k like 10... exactly what the car needs, it's a 99 integra daily driven
Old Feb 18, 2007 | 08:06 PM
Mike@K-Tuned's Avatar
Default Re: LS/VTEC Dyno (NA-PR-CRX)
Nice power and nice midrange. Exactly what changes were made? I do see you richened it up a bit but could you detail what else you changed to make the improvements.
Old Feb 18, 2007 | 08:27 PM
NA-PR-CRX's Avatar
Default Re: LS/VTEC Dyno (LSvtecMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtecMike &raquo;</TD></TR><TR><TD CLASS="quote">Nice power and nice midrange. Exactly what changes were made? I do see you richened it up a bit but could you detail what else you changed to make the improvements. </TD></TR></TABLE>
the header-exhaust with a cut out and oem muffler instead of only a muffler, injectors were added and p28 ecu with crome, before a spoon obd2 one with field
Old Feb 19, 2007 | 12:40 AM
acydphryck's Avatar
nice gains throughout power band...congrats!!
what kind of fuel pump are you using with that setup?
Old Feb 19, 2007 | 06:21 AM
flesh199's Avatar
Default Re: LS/VTEC Dyno (acydphryck)
torque gain are huge
Old Feb 19, 2007 | 08:55 AM
NA-PR-CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck &raquo;</TD></TR><TR><TD CLASS="quote">nice gains throughout power band...congrats!!
what kind of fuel pump are you using with that setup?</TD></TR></TABLE>
walbro 255
Old Feb 21, 2007 | 08:16 PM
B18C1_POWER's Avatar
nicee
Old Feb 21, 2007 | 10:05 PM
salman's Avatar
awsome power
E.J.
Oct 2, 2004 10:10 PM
jr_istheman
14
Jan 12, 2004 11:14 AM
B16b2b
Oct 7, 2002 04:50 PM
sgT
Mar 25, 2002 01:20 PM
LSR 97
Aug 11, 2001 08:33 AM
