Disconnecting the battery after installing a K&N Air Filter
Do you need to disconnect the battery after installing a K&N Air filter? Or will the vehicles CPU automatically adjust the air fuel ration. 2006 Honda Accord.
You don't need to reset the ECU when installing a new air filter (regardless of type). You have a MAP sensor where the air intake meets the throttle body and you have an Oxygen sensor inside the exhaust headers that will regulate the fuel/air mixture.
A bunch of other sensors as well but these are some of the main ones.
EJ8_Enthusiast
Mar 23, 2011 01:26 PM
luckyzz
Apr 28, 2004 07:13 AM
adding, air, battery, disconnect, disconnecting, ecu, filter, filters, installing, intake, kn, reason, reset, resetting, unhook
