Timing belt broke...Is this damage?
My timing belt broke last night. I did the manual tensioner conversion about 3 weeks ago, and I'm sure I did something wrong since this happened. I ran up to 40 in first gear and threw it into 4th. I speed up to about 50 when the motor died. When I checked to see what had happened, that's when I found the broken timing belt.
My question: I opened up the head and found what I think is damage, but I don't see what could have happened to do this.
This is a wall that I think looks good. They are both right about the rocker arms.
It looks like obvious damage...I just CAN'T see how it would happen...especially if I didn't hear anything.
Modified by 1GPlusSH at 4:02 PM 2/18/2007
Fix the pictorz
There's no way to visually tell if you bent valves with them still in the head...or even if they're out of the head for that matter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude252 »</TD></TR><TR><TD CLASS="quote">COMP. test</TD></TR></TABLE>
the timing belt is broken, makes it alittle hard for a comp test. leakdown will give you better answers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">Might be ok if you were not in VTEC when it broke. Time it with a new belt and check compression.</TD></TR></TABLE>
EXACTLY!!!!!
EXACTLY!!!!!
