1993 Accord Overheats
Old Feb 18, 2007 | 07:32 AM
civicboisi's Avatar
Default 1993 Accord Overheats
I recently replaced the thermostat in my Accord and bled it threw the bleeder and the radiator cap. Ever since, it would overheat after awhile of driving when i come to a stop. I tried rebleeding the system and eliminating air out of the system. It never did this with the original thermostat either which is weird.
I understand that they have 2 different types of thermostats for this vehicle and i'm using the one with the pin on the side, since thats what came out of it before.
Any ideas? Is there a link for bleeding the coolant system to fully eliminate air from the coolant system?
EDIT: After doing some searches about this topic on here and CD7Tuner, the pin on the side of the thermostat has to be facing up? This might be my problem then...and the lower radiator hose is cool...not warm/hot like the upper radiator hose.
TIA
Modified by civicboisi at 8:58 AM 2/18/2007
Old Feb 18, 2007 | 08:13 AM
gulfview's Avatar
Default Re: 1993 Accord Overheats (civicboisi)
You could double check at a parts stote to see if you have the correct radiator cap -- like the pressure number.
Is your radiator full of coolant? All you need to do is fill it up and drive it and then let it cool down and fill it up again. That should do it.
Are your radiator hoses good? Do they maintain their shape, instead of collapsing?
Old Feb 18, 2007 | 08:47 AM
hondadude's Avatar
Yes the little pin hole should be facing up, and the 'spring side' of the T-stat goes toward the engine not toward the radiator hose.
Was overheating the original reason for changing the T-stat?
Old Feb 18, 2007 | 11:23 AM
civicboisi's Avatar
Default Re: 1993 Accord Overheats (hondadude)
Yes the radiator is always full when i check it. Hoses are good and maintains their shape.
No. The reason for changing was due to lack of heat. It never overheated or ran warm i should say before the new thermo was put in. I'll double check the installation tomorrow at work.
Thanks guys.
Old Feb 22, 2007 | 02:18 PM
civicboisi's Avatar
So i rechecked the thermostat...it was completly 180 so i flipped it upwards (the pin) and she still overheats...WTF?
Upper hose is still alot hotter then the lower radiator hose...could it be a clogged radiator?
Confuzzled
Old Feb 22, 2007 | 04:37 PM
BLKFLSH's Avatar
I suppose the thermostat could be bad. Stick that sucker in some boiling water, and see if it opens up.
Old Feb 22, 2007 | 05:38 PM
civicboisi's Avatar
Default Re: 1993 Accord Overheats (BLKFLSH)
This is odd. The car never overheated with the old one in...every new thermo i put in seems to make it overheat...
luvinthelude
Feb 11, 2014 06:17 AM
snowblind7x
May 21, 2009 12:28 AM
B18c1vicrx
May 13, 2009 01:01 PM
greenleg88
Mar 8, 2009 10:04 AM
