Two hoses under throttle body?
Old Feb 17, 2007 | 10:17 PM
EKHWhat's Avatar
Default Two hoses under throttle body?
Where do the two hoses go to under the throttle body on a H22A?
Its on the valve that bolts directly up to the throttle body.
Old Feb 17, 2007 | 10:26 PM
ludekid4323's Avatar
Default Re: Two hoses under throttle body? (EKHWhat)
I am sooo druck now that I have no Idea what u are talking about...sorry
Old Feb 17, 2007 | 10:28 PM
EKHWhat's Avatar
...Okay. Well that really doesn't do my any good then.
But, thanks for the conversation I guess.
Old Feb 17, 2007 | 10:36 PM
ludetunerz's Avatar
If its the coolant hoses you're talking about, its for the Idle Air Control
Old Feb 17, 2007 | 10:38 PM
EKHWhat's Avatar
Im not sure it there coolant hoses though.
I dont think its for the idle air contol valve, but there are two hoses coming out of the IACV that have coolant going to/from them.
Its like directly under the intake port.
Old Feb 17, 2007 | 10:39 PM
Hawkze_2.3's Avatar
Default Re: Two hoses under throttle body? (ludetunerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludetunerz &raquo;</TD></TR><TR><TD CLASS="quote">If its the coolant hoses you're talking about, its for the Idle Air Control</TD></TR></TABLE>
Nooo...the 2 hoses are for the FITV (fast idle thermo valve). They provide engine coolant to that valve to keep the idle high until a certain temp is reached. They just go back to the engine from the valve.
Old Feb 17, 2007 | 10:42 PM
EKHWhat's Avatar
where do those two plug in?
Well now I need to know where the two hoses go off the IACV. Are those just for coolant as well?
EKHWhat's Avatar
WHere do they plug into then?
Also, where do the hoses go to from the IACV on the front of the IM?
Old Feb 17, 2007 | 10:46 PM
Hawkze_2.3's Avatar
Default Re: (EKHWhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKHWhat &raquo;</TD></TR><TR><TD CLASS="quote">WHere do they plug into then?
Also, where do the hoses go to from the IACV on the front of the IM?</TD></TR></TABLE>
You mean where do they go on the engine?
Look up the diagrams on http://www.slhondaparts.com. There's no way to explain it in words...
Edit, below is the H23 diagram, the H22 diagram is further down
Modified by Hawkze_2.3 at 6:09 PM 2/19/2007
Old Feb 17, 2007 | 10:51 PM
ludetunerz's Avatar
Default Re: Two hoses under throttle body? (Hawkze_2.3)
I know the Fast Idle Valvw has coolant hoses on it, but doesn't the IAC as well?
Old Feb 17, 2007 | 10:53 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludetunerz &raquo;</TD></TR><TR><TD CLASS="quote">I know the Fast Idle Valvw has coolant hoses on it, but doesn't the IAC as well?</TD></TR></TABLE>
Yes, but he was originally just asking about the valve under the TB...oh well.
Old Feb 18, 2007 | 04:45 AM
vtech_is_4_phones's Avatar
hate does not even begin to describe my feelings for the FITV and the IACV
Old Feb 18, 2007 | 06:26 AM
mdpc20653's Avatar
iac?
Old Feb 18, 2007 | 07:33 AM
EKHWhat's Avatar
I am not sure that I have any of those valves on my motor. Haha.
The thing in the middle of the page that number 5 goes to is supposed to be what?
And what exactly is the thing directly to the right of the intake manifold?
None of those look firmilliar.
Old Feb 19, 2007 | 02:57 PM
SikB's Avatar
That is not the right picture. The lower intake manifold and thermo housing are different in the h22 and h23 and that pic is for the h23. You can find both diagrams in a service manual. I don't have the pic handy.
Edit: I am sorry, to answer you last question more directly hoses # 2, 3 and 5 plug in to the manifold right below the egr valve. Your EGR valve is in the same spot but you don't have those connections.
Old Feb 19, 2007 | 05:08 PM
Hawkze_2.3's Avatar
Default Re: (SikB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikB &raquo;</TD></TR><TR><TD CLASS="quote">That is not the right picture. </TD></TR></TABLE>
Oops, you're right...here's the H22 diagram.
Old Feb 19, 2007 | 05:24 PM
EKHWhat's Avatar
thanks alot man. Now I got it figured out.
EFstyle
Jul 29, 2008 07:09 PM
dem0nk1d
14
Mar 22, 2006 05:57 PM
99ctr
Oct 5, 2005 12:23 PM
smash fascism
Apr 10, 2005 06:39 AM
