Mounting battery in new location???
im finishing up my race car and want to mount my battery in the inner fender... ive seen this in EGs DCs and EKs but never on a crx... i mean im pretty sure its been done... the question im asking is will a stock EG size battery fit on the inner fender fit with the stock bumper on? please let me know if its possible. thanks
does anyone have pictures on CRX batterys that they have moved to a new location.... i have a k20 and i was thinking about mounting it on the inner drivers side by the tranny but i was trying to worry alittle about the weight distrabution... if you look in this picture in the far right corner you can bairly see it... this is where i was thinking about mounting it. there or on the passanger outer fender
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cidone »</TD></TR><TR><TD CLASS="quote">ya i guess im just kinda scared about corner weight....</TD></TR></TABLE>
i mounted the battery like you pictured above on a customer's car,only on the passenger side(it was a B-series engine,so the passenger side worked better).no problems,and i wouldn't worry too much about it affecting weight distribution.
Chris
Chris
welding/fab
something like this?
tony1 did something similar that was very clean, strong and simple but the pic is quebrado..
https://honda-tech.com/zero...age=1
So corner scale it....
I think your a little heavy on the passenger side anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hyaboosta »</TD></TR><TR><TD CLASS="quote">Is it legal in NHRA to place the battery in the fender well without a kill switch? can you place a dry cell Motorcycle behind the dash and pass tech?
thanks</TD></TR></TABLE>
As far as i know the rules now state you only need a kill switch if it's in the driver's compartment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">anytime the battery is moved from stock location you need a cut off switch... even sealed dry cell batterys need a box i learned that last season...</TD></TR></TABLE>
even if it is moved to the fenderwell? that doesnt make sence. i can understand if your moving it to the drivers compartment by why does it need a cutoff if your only going to the fenderwell?
The rule book contradicts itself it seems. In general regulations it says you need a cut off switch if the batter is relocated anywhere. Under the class regulations (for SFWD for example) it says if the battery is relocated to the trunk you need one.
"MASTER CUTOFF:
Mandatory on any vehicle running 9.99 or quicker, or 135 mph or faster, or on any vehicle where the battery has been relocated to the trunk of vehicle. See General Regulations 8:4"
"8:4 MASTER CUTOFF
Mandatory when battery is relocated or on any vehicle running 9.99 or quicker. An electrical power cutoff switch (one only) must be installed on the rearmost part of each vehicle and be easily accessible from outside the car body. The cutoff switch must..."
http://www.nhrasportcompact.com/2007/rules/
"MASTER CUTOFF:
"8:4 MASTER CUTOFF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cidone »</TD></TR><TR><TD CLASS="quote">does anyone have pictures on CRX batterys that they have moved to a new location.... </TD></TR></TABLE>
I do. Not a CRX but an 88 hatchback. It's an Nrg-cell battery, not a stock sized battery. Made a bracket for it and placed it in front of the transmission.
The_Honda_Guy
Nov 21, 2008 03:24 PM
pyro_freak8
10
Jan 8, 2004 02:27 PM
