Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Front LCA Integra Spherical Bearing Kits are ready
Old Feb 17, 2007 | 06:34 PM
577HondaPrelude's Avatar
Default Front LCA Integra Spherical Bearing Kits are ready
Several of you guys experesed enterest in a spherical bearing kit for the front Lower Control Arms for your Integras. I got a batch of them in from my machinest and they are ready to send out. You can get them from my web site via the link below:
http://www.mckinneyraceworks.c...id=51
Price = $105 + $10 flat shipping rate to USA.
It is a direct replacement of the OEM bushings, press fit into the control arms.
If for some reason you don't want to go through the web site, send me a PM.
Pictures:
Old Feb 17, 2007 | 06:48 PM
Crx Jimmy's Avatar
Default Re: Front LCA Integra Spherical Bearing Kits are ready (577HondaPrelude)
do these fit any other cars? like crx's
Old Feb 17, 2007 | 07:24 PM
ginsu2k's Avatar
Do you know if these will fit the rear control arm (92-95 Civic), either inboard, outboard or both?
Old Feb 17, 2007 | 10:48 PM
seek167's Avatar
Default Re: Front LCA Integra Spherical Bearing Kits are ready (ginsu2k)
are you gonna have these in a month
Old Feb 18, 2007 | 04:45 AM
an2ny888's Avatar
how's the durability? how many miles are these expected to last?
Old Feb 18, 2007 | 05:07 AM
VTECAcuraGSR's Avatar
Are you concerned that with the bearing being not as wide as the LCA itself, that there may be too much load on the bearing with not enough area to spread the load?
Old Feb 18, 2007 | 07:26 AM
Default Re: Front LCA Integra Spherical Bearing Kits are ready (VTECAcuraGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Are you concerned that with the bearing being not as wide as the LCA itself, that there may be too much load on the bearing with not enough area to spread the load?
The bearings are heavy duty and can withstand much more force than a car with even race tires can produce. These bearings are rated to withstand more than 25,000 lbs of force.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">how's the durability? how many miles are these expected to last?</TD></TR></TABLE>
I have used them on my prelude for 1.5 years with about 20 track days and the bearings are still good and tight. If or when the bearings start to wear out and get loose they can be replaced by hand with new bearings for about $30 (for 2).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">are you gonna have these in a month</TD></TR></TABLE>
They are in stock now, and I should still have them in a month.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">do these fit any other cars?</TD></TR></TABLE>
I have kits for the prelude, integra, and accord. I will have to check it they will fit other cars, but I would guess they do not. I'm working on a kit for the EK civics but they are not ready yet.
Old Feb 18, 2007 | 07:55 AM
smokin rubber's Avatar
is that a metal bushing for the lower shock mount?
Old Feb 18, 2007 | 08:50 AM
Default Re: (smokin rubber)
no, it's for the LCA were it connects to the chassis of the car.
Old Feb 18, 2007 | 09:34 AM
Lo-Buck EF's Avatar
Default Re: (577HondaPrelude)
awsome product.
Old Feb 18, 2007 | 10:37 AM
Any reason not to build a LCA shock mount setup? I have been told this is the most improvement in the handling as far as the mounts go.
Old Feb 18, 2007 | 04:24 PM
an2ny888's Avatar
Default Re: (VTECAcuraGSR)
i've heard otherwise, that the shock mount bushing in the front lca produces the least improvement when replaced by a poly or any aftermarket bushing.
Old Feb 18, 2007 | 04:27 PM
an2ny888's Avatar
Default Re: (an2ny888)
another question, do these make any noise or produce more impact harshness compared to stock bushings? also $105 is for a pair right?
Old Feb 18, 2007 | 04:49 PM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">another question, do these make any noise or produce more impact harshness compared to stock bushings?</TD></TR></TABLE>
Is that a serious question?
OEM bushings (on any car) are made from varying hardnesses of rubber to reduce noise, vibration and harshness. Solid steel spherical bushings are about as bad as it gets, NVH-wise. They are for racing use, where you shouldn't care...
Old Feb 18, 2007 | 04:56 PM
ITAcelica's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">another question, do these make any noise or produce more impact harshness compared to stock bushings? </TD></TR></TABLE>
Wow.
Old Feb 18, 2007 | 05:20 PM
Track rat's Avatar
Default Re: (ITAcelica)
I just hit the site, ordered and paid.
Thanks Walter!
Old Feb 18, 2007 | 05:22 PM
yes it's for a pair of 2. 1 for each side. Yes they will transmit more road noise into the chassis. These kits are for competition use were every fraction of a second matters and things like noise and ride harshness take a back seat.
Old Feb 19, 2007 | 10:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">no, it's for the LCA were it connects to the chassis of the car.</TD></TR></TABLE>
But in the second pic, the hole for the shock looks to have a metal piece pressed in.
Old Feb 19, 2007 | 01:04 PM
slammed_93_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokin rubber &raquo;</TD></TR><TR><TD CLASS="quote">
But in the second pic, the hole for the shock looks to have a metal piece pressed in. </TD></TR></TABLE>
that is not were the shock mounts. that is were the rear portion of the LCA mounts to this part
DNA-Motoring
Dec 15, 2014 03:28 PM
emgjsdk1
May 16, 2010 10:09 AM
over_
Honda Civic (2001 - 2005)
42
Mar 25, 2008 08:23 PM
93dabeast
Feb 8, 2006 10:47 AM
2000Accord5sp
Dec 11, 2002 07:45 AM
