crankshaft bridge damage
Old Feb 17, 2007 | 05:20 PM
ge_itr's Avatar
Default crankshaft bridge damage
i just notice some damage on the crankshaft bridege. i was wondering if you guys think if this is still okay. or should i buy one from 92hondalude for $45 + shipping?
anyways... i just got my wiseco pistons. 89mm 12.0:1. still waiting for the custom crankshaft.
Old Feb 17, 2007 | 07:12 PM
Rosko's Avatar
Default Re: crankshaft bridge damage (ge_itr)
well if its not punctured then I'd say go for it.
Old Feb 17, 2007 | 07:14 PM
nonvteclude's Avatar
Default Re: crankshaft bridge damage (Rosko)
im curious to know what hit it to do that
Old Feb 18, 2007 | 08:37 AM
ge_itr's Avatar
i broke one of my rod. the biggest dent is punctured about 1/4 inch.
Old Feb 18, 2007 | 08:45 AM
md23vtec's Avatar
Default Re: (ge_itr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote">i broke one of my rod. the biggest dent is punctured about 1/4 inch.</TD></TR></TABLE>
Damn you got lucky it didn't come threw the block . I would just get those marks filed off or sand them down . The problem with switching the main caps is the fitment . It could be a pain in the *** and also on the expensive side to get it line honed and done correctly. Then bearing selection yadda yadda... In<U> some</U> cases you would be better off just getting another block before you switch the main caps. If the bearing surfaces are good then I would stick with the ones you already have
Old Feb 18, 2007 | 11:20 AM
ge_itr's Avatar
Default Re: (md23vtec)
the bearing surfaces are okay. so it would be pretty hard to put in a different one in?
Old Feb 18, 2007 | 05:12 PM
PirateMcFred's Avatar
If there are no cracks or leaks, it will probably work fine. It should be possible to touch it up with a tig welder if you're worried about it.
Patrick
Honda Motorcycles
12
Jun 3, 2008 11:35 AM
jason DB8
Aug 13, 2007 11:15 PM
...rohit
Honda Motorcycles
26
May 25, 2007 12:14 AM
Josh95
Nov 7, 2005 04:49 PM
koncept1
Welding / Fabrication
Sep 22, 2005 06:27 PM
