Jerking during heavy acceration??
Old Feb 17, 2007 | 09:21 AM
HImiles's Avatar
Default Jerking during heavy acceration??
Hey guys,
Vehicle: 1991 Honda Accord LX 2dr 5sp. (unmodded)
Mileage: 282k but well maintained
Problem: Momentary hesitation\lack of acceleration\studder occuring ONLY at low rpms (1000-2000) during heavy acceleration. The problem occurs in every gear at low rpm, and more dramatically when I shift up into higher gears prematurly and hit the gas significantly.
Please note: this problem does not occur at higher rpms and only hesitates once for each gear change. It is a momentary hesitation that does not reoccur until I shift up into the next gear and gas it heavy.
What do you think? TPS, injector, maf sensor, egr??
The air filter is clean btw. Could it be something as simple as a clogged fuel filter??
You all rock!!!!!!
Thanks
Modified by HImiles at 11:10 AM 2/17/2007
Old Feb 17, 2007 | 09:23 AM
95CDSedan's Avatar
I'd say with 282K on it if thats your only problem thus far your doing decent. LOL But it could be any of those just check them out.
Old Feb 17, 2007 | 11:49 AM
Accord2k-Hybrid's Avatar
Default Re: Jerking during heavy acceration?? (HImiles)
low RPM hesitation is usually your EGR, but it could be any of those items you listed, if you've never cleaned/replaced the EGR valve, it may be time.
Like previously said, just do a check of everything affecting fuel and air and you should find your problem.
russelbit
Nov 28, 2009 11:12 PM
`chrisb
Feb 26, 2008 03:33 PM
Apocolipse269
Feb 12, 2007 10:30 AM
meagainsttheworld
Apr 15, 2006 08:08 AM
hondafan2000
Jun 25, 2004 09:31 PM
