JDM Cluster swap
Old Feb 17, 2007 | 08:52 AM
rondigs's Avatar
Default JDM Cluster swap
...nope not looking to find out how to switch the USDM cluster to the JDM cluster.
Has anyone ever tried to put a USDM speedo in a JDM cluster? Is it possible?
Old Feb 17, 2007 | 09:41 AM
rondigs's Avatar
Default Re: JDM Cluster swap (JJSpecTuning)
Sure that'll work too. I've never tried it. Is it pretty simple?
Old Feb 17, 2007 | 09:50 AM
rondigs's Avatar
Default Re: JDM Cluster swap (rondigs)
After vigorous searching found this. Not a DC2 cluster, but makes me hopeful:
https://honda-tech.com/zerothread?id=1537664
Old Feb 17, 2007 | 10:36 AM
Markland Photo's Avatar
^^^ making the best out of a stock dx cluster haha
looks pretty good
Old Feb 17, 2007 | 01:48 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rondigs &raquo;</TD></TR><TR><TD CLASS="quote">After vigorous searching found this. Not a DC2 cluster, but makes me hopeful:
https://honda-tech.com/zerothread?id=1537664</TD></TR></TABLE>
that's a lot of ******* work for just a cluster
If you put a jdm speedo in a usdm cluster, it won't be accurate as the speed COULD be in a different sweep of the needle.
just get the whole thing
Old Feb 17, 2007 | 04:14 PM
rondigs's Avatar
Default Re: JDM Cluster swap (FalkenSiR)
It's not about buying the whole setup. I have a JDM ITR cluster and a GSR cluster. I want the looks/tach of the JDM cluster. However, I want the higher MPH reading offered on the GSR panel.
Hence combine them both...
Weak!EG
May 7, 2007 11:07 PM
Weak!EG
May 7, 2007 09:07 PM
cltitus
Mar 15, 2007 07:41 AM
BlueIntegraBoy
Feb 17, 2004 09:56 PM
