car idles at 2.5k rpm
already so i tried doing the whole h23 im swap but it went bad so i put my old f22bx im on. its throwing a code but i dont know how to check it. i unplugged the tps sensor and nothing happens, does that mean its gone bad because i took that one off to put it on the h23 im when i tried that swap. so is that the problem?
https://honda-tech.com/zerothread/1171263
^^^how to check your CEL^^^ it's in the civic forum but it's the same for 5th gen accords for the most part, you can also look it up in a haynes or chiltons manual.
Check your CEL, figure out what you might have forgot to connect or which sensor is bad and fix it.
