Rear str8 axle
Old Feb 16, 2007 | 11:37 AM
SilverCoupeEj8's Avatar
Default Rear str8 axle
I'm looking into buying a str8 rear axle...from what i've heard it mainly for drag racing and drops weight by about 60lbs...anyone know where to buy one? and would this be ok for very light street duty? would you be able to put 16x7 wheels on?? its not a big concern i'm just wondering... the car will be a weekend drag car but very very light street driving...i was told that regular wheels wont fit because how its made. Thanks for your help
Old Feb 16, 2007 | 11:43 AM
Hardt's Avatar
Default Re: Rear str8 axle (SilverCoupeEj8)
No
Old Feb 16, 2007 | 11:45 AM
no.. what? Its not a serious item ... i'm just wondering about it and couldnt find any info detailing about it.
Old Feb 16, 2007 | 11:51 AM
4piston's Avatar
Default Re: (SilverCoupeEj8)
Which straight axle are you looking at? My Ken's axle dropped maybe 30 lbs after I cut the subframe out and you could NOT run anything other than skinnies with it.
If it is a street driven car I would leave it alone.
Old Feb 16, 2007 | 12:10 PM
Thanks for the reply... i wasnt sure... i remember back in the day, a company had one that they use to sell.. and there out of business now... and i wanted to se if another company sold it.. and what were the details on it. Thanks i'm just gonna stick with stock..
Old Feb 17, 2007 | 07:44 AM
1 2 NV's Avatar
i remember when MB sold their straight axle they claimed it dropped 80lbs. first off both trailing arms with brake assemblies dont weigh 80lbs combined. now if you added the struts, springs and rear tires that might save you 80lbs total, i think thats even pushing it.
Old Feb 17, 2007 | 07:51 AM
d16dcoe45's Avatar
Default Re: Rear str8 axle (1 2 NV)
I remember MB (?) the guys who used to sell the one piece front ends, hatches and doors--used to advertise a narrowed drag rear end that saved around 60-70 lbs. It wasn't a straight axle, but it converted the double wishbone/trailing arm suspension into a strut suspension--used a different lower control arm, no upper arm, and a thin tubular trailing arm (you ditched the original OEM trailing arm). The strut performed location duties. It was a whole package with their own hub bearings and disc brakes.
I have never driven a Honda with an aftermarket straight axle, but I would imagine it is strictly for straight line racing only. Its not worth it at all if you are still going to be doing "some" street driving.
Old Feb 17, 2007 | 07:52 AM
1 2 NV's Avatar
Default Re: Rear str8 axle (d16dcoe45)
thats the ones. they made that IRS and the straight axle both. i believe your right 60lbs or so from the IRS and 80 from the straight.
Old Feb 17, 2007 | 07:55 AM
d16dcoe45's Avatar
There was a time in early 2000, when I almost got the "narrow" one piece front end to drive on the street with---I was going to cut out holes for headlights. Thank goodness I never did that!
Old Feb 17, 2007 | 08:01 AM
1 2 NV's Avatar
the guy (matt) i got my MB front end from had a 1 piece on his street driven CRX. i guess that old white coupe that used to be advertised (MMR) along with MBs product was also his at one point.
Old Feb 17, 2007 | 09:15 AM
NativeSon's Avatar
Default Re: (4piston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston &raquo;</TD></TR><TR><TD CLASS="quote">Which straight axle are you looking at? My Ken's axle dropped maybe 30 lbs after I cut the subframe out and you could NOT run anything other than skinnies with it.
If it is a street driven car I would leave it alone.</TD></TR></TABLE>
No, he wanted info on a str8 axle.
Old Feb 17, 2007 | 09:34 AM
d16dcoe45's Avatar
Default Re: (NativeSon)
Matt's CRX--if its the one I am thinking of, was so awesome!! He had the one pice front with exposed headlights and the bottom painted black to match the stock CRX sideskirts--and the rest of the car was silver--is that right? I heard he also had a 180 whp d16z6 NA setup. Do you have any pics of the exterior and engine bay of that car?
Old Feb 17, 2007 | 09:36 AM
1 2 NV's Avatar
Default Re: (d16dcoe45)
thats the one. i never saw pics. i remember talking to him about his car. he put down 190 or so with that SOHC. he said his car might have appeared street legal but his gf at the time could pick up the rear of the car. it was somewhere around the 1700lb range if i remember correctly. this was like 5 yrs ago or more.
RedneckRicer
Jul 7, 2009 02:47 PM
sj-performance
Dec 20, 2008 09:24 AM
E-AT_me
16
Jul 12, 2008 11:22 PM
guttedsilvercrx
Dec 2, 2003 03:29 PM
