accord help
Old Feb 15, 2007 | 11:53 PM
krytoi's Avatar
Default accord help
i drive an accord and when i hit like 65 and try to hit legt and right it seems like my tires are flat and i check the pressure and its all good any1 knows wat that could be?
Old Feb 16, 2007 | 05:01 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: accord help (krytoi)
huh?
what exactly are you asking?
maybe try to be more descriptive in your title and post...
Old Feb 16, 2007 | 10:55 AM
krytoi's Avatar
well when u drive u go left right left it feels like u have a flat tire but its not flat u know wat that could be
Old Feb 16, 2007 | 10:56 AM
H-T Order of Merit
Default Re: (krytoi)
so basically your saying the car pulls to one side or the other while driving?
When was the last time you had an alignment?
Old Feb 16, 2007 | 01:43 PM
krytoi's Avatar
no its not that im saying is that when u turn left than right the car feels like it has a flat tire i turn smooth and not so steady and i dont know wat is it i checks the tire pressure and its all good
Old Feb 16, 2007 | 01:47 PM
Accord2k-Hybrid's Avatar
are you talking about abruptly turning left and right then left and right at a high speed and you get that feeling like your car is floating on a flat?
ya, that's normal, it's your tire's reaction to the motion and the friction with the ground.
Try it in another car, it'll do the same thing.
Old Feb 16, 2007 | 01:57 PM
krytoi's Avatar
yeah u know wat im talking about but i had some hella bold *** tires and it didnt do that and it was hella low can it be cuz changed the tires and got the car up a lil more?
Old Feb 16, 2007 | 02:03 PM
I've never done that on bald tires, frankly I'd be scared to unless I was on a skid pad.
it's probably the distance from where the tires meet the ground to where the rim meets the tires, add in a little suspension flex and that's pretty much what you're moving.
Old Feb 16, 2007 | 02:10 PM
krytoi's Avatar
cound it be lower tie bad loose or something like that or should i get the tires a lil bit flatter
Old Feb 16, 2007 | 02:14 PM
H-T Order of Merit
Default Re: (Accord2k-Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord2k-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about abruptly turning left and right then left and right at a high speed and you get that feeling like your car is floating on a flat?
ya, that's normal, it's your tire's reaction to the motion and the friction with the ground.</TD></TR></TABLE>
What!? Thats not normal. Your car should never abruptly sway left or right at any speed. Maybe it's the way your describing it.
Did you just start experiencing this after putting new tires on?
The last tires I had on my Accord were Kumho tires and they followed the road more than any tire I've had before. By this I mean, depending on the road I was on the car would pull in different directions. Not abruptly change direction, but a pull to one side or the other. My car had a good alignment, proper tire inflation, and after reading multiple reviews on the tires I figured it was the tire that was just following the road, nothing wrong with the car and nothing that could be done.
But if your getting abrupt direction changes then something is wrong.
So I'll ask again, when did you get your last alignment?
Old Feb 16, 2007 | 02:16 PM
Default Re: (TouringAccord)
the abrupt I was defining as YOUR OWN INPUT to the vehicle, not a response from the vehicle.
Edit: and I've had my car aligned twice since I've put tein coilovers in and I have the Kumho excedes (however it's spelt) my last alignment was done 3 months ago after I installed rear camber adjustments.
Old Feb 16, 2007 | 02:22 PM
get in your car, get on the freeway, get up to about 65-70 and make the steering wheel move (as if the top were 0 degrees) from 0 to 345 and then to 25, a full 50 degrees in rotation from left to right, now do the reverse the moment you reach 25 for another 50 degrees of rotation, repeat this untill you feel your car wobble.
Old Feb 16, 2007 | 02:58 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord2k-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">get in your car, get on the freeway, get up to about 65-70 and make the steering wheel move (as if the top were 0 degrees) from 0 to 345 and then to 25, a full 50 degrees in rotation from left to right, now do the reverse the moment you reach 25 for another 50 degrees of rotation, repeat this untill you feel your car wobble.</TD></TR></TABLE>
yeah, uh, no. Why would anyone do that?
Also, I wasn't asking you about your alignment, I was asking the OP like I did earlier.
Old Feb 16, 2007 | 03:07 PM
I do it when I'm extremly bored on long road trips occasionaly.
it just sounded like what he was describing, and I know what that feels like, so I explained it.
Old Feb 16, 2007 | 03:17 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord2k-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I do it when I'm extremly bored on long road trips occasionaly.</TD></TR></TABLE>
wow, ok. no offence, but I hope you don't "road trip" up here to Michigan
I wouldn't want to encounter someone doing that.
Old Feb 16, 2007 | 03:25 PM
I've actually seen someone else do it before, it's a rather bizare sight.
I mostly do it to get a reaction from my passenger.
Never do this under any other weather condition than dry pavement, or you'll end up in the median, possibly backwards. No that's not from experience.
Old Feb 16, 2007 | 03:50 PM
krytoi's Avatar
lol ye i got new tires and it start doing that i should check the eliement but it feels weird never had that before on any car
samster911
Jul 11, 2015 02:49 PM
MSchu
Aug 30, 2008 08:29 PM
emoze
Jun 5, 2007 07:27 PM
JimmyM86
Dec 23, 2006 10:26 PM
lost-in-space
Aug 13, 2004 08:10 AM
