How do you make your turn signals blink fast?
Old Feb 15, 2007 | 07:11 PM
EvenStar's Avatar
Default How do you make your turn signals blink fast?
95 accord lx.
I know it has something to do with modifying the relay. How exactly do I get to the relay and removing it? And how do I modify it to blink fast?
Old Feb 15, 2007 | 07:13 PM
hondadude's Avatar
Default Re: How do you make your turn signals blink fast? (EvenStar)
Try this link I think it has the info you are seeking;
http://www.cryogen97.net/howto/hyperblinker.html
Old Feb 15, 2007 | 07:18 PM
EvenStar's Avatar
Default Re: How do you make your turn signals blink fast? (hondadude)
so there is just one relay that controls the whole signal?
Old Feb 15, 2007 | 07:21 PM
hondadude's Avatar
yeah I'd guess from reading that webpage; The setup is really a R C circuit, changing the resistance causes the cap to charge/discharge at different rates.
Old Feb 15, 2007 | 07:34 PM
EvenStar's Avatar
cool.
now about the "alternative blinking relays" since i dont have any soldering tools to make the adjustable blinkers. i just take out that resistor and plug the relay back in and thats it?? what about the colors he was describing (#4?)??
Old Feb 15, 2007 | 07:45 PM
Accord2k-Hybrid's Avatar
Default Re: (EvenStar)
the colors are the colors you'll be reading on the resistor.
there's no guarantee you're going to like what you get by removing that resistor, the blinks per minute may go a lot faster than you want since the capacitor is allowed to charge/discharge faster without it.
I guess what I'm saying is, do at your own risk.
in order to "properly" remove that resistor you're probably going to need a soldering iron, and actually KNOW how to solder/desolder. If you just REALLY don't care, dyke it, but you'll have to find a replacement resistor, a soldering iron and learn how to solder in order to get your blinkers to function stock again, or just replace the whole unit with a new one.
Old Feb 15, 2007 | 07:54 PM
EvenStar's Avatar
ok, ill assume that the colors on #4 is the correct resistor to remove in his guide?
Old Feb 15, 2007 | 09:53 PM
sony224422's Avatar
jw, why do you want them to blink faster. you might want to think about that. my friend did it and he got exteremly annoyed with it after the first few days. its quite annoying when its clicking really fast.
Old Feb 16, 2007 | 03:11 AM
K24.20A's Avatar
Yeah im planning to do that configuration on my car as well but instead make them slower, I will post up a DIY post for everyone. Hopefully soon. I hope you check it out and see whether you like it or not. I will also post a video to show you how slow or fast it will be. Well good luck for now.
Old Oct 17, 2011 | 11:10 PM
CaSpAr4Rm916's Avatar
i'll just do it the easy way i know how, remove the bumper signal light, then cut the center wire, leave a couple inches just in case u cut the wrong wire. LoL
Old Oct 18, 2011 | 01:34 AM
TypeRMOBBiN209's Avatar
put a bulb in that blew out or cross the red and green wire on the turn signal lol..thats how i did them
D7KWagon
Aug 5, 2014 01:57 PM
Mr.Speed
Dec 19, 2008 01:07 PM
