95 Accord Antenna
Does anyone know where to get a good replacement for the stock metal antenna on a 95 accord? My 95 accord has the motor broke that extends the antenna meaning the only inexpensive solution is to leave the antenna exposed and ready to be bent unless I want to get out of the car and push it up and down everywhere I go. Is there any place that sells a more flexible antenna that could be put on my accord? I know it's hard to find one that fits it.
The antenna motor is dead? Or is the antenna just not running as in a broken mast lead?
Here's a link that might help you to check it out further;
http://members.troublecodes.ne...a.htm
there is a simple fix in most cases, take the motor apart and flip the gear over and reassemble or get another one from a JY if a dealer costs is more than $40
It's the part that extends and retracts the antenna when you start and turn off your car. I think they made it on the 94 and 95 accords(had this happen on a 94 accord that I used to have as well). Dealerships give I pretty outrageous price that doesn't seem worth it. I was hoping there was some flexible antenna that would be permanately extended. YeuEmMaiMai, what is a JY?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">The antenna motor is dead? Or is the antenna just not running as in a broken mast lead?
http://members.troublecodes.ne...a.htm</TD></TR></TABLE>
Thanks hondadude! I took apart my jammed up 94' EX power antenna last night and cleaned it all out according to your directions and now goes up and down like butter!
r3000
Dec 15, 2004 07:24 PM
