what setup do you think will be more powerful?
Old May 20, 2002 | 04:00 AM
Phoenix GSR's Avatar
Default what setup do you think will be more powerful?
what setup do you think will be faster?
B20 bottom end /w type r head +I/H/E
(couldnt afford pistons so - more displacement /w less compr.)
or
stock b18c5 /w I/H/E (less diplacement, more compression)
TIA
-Dan
Old May 20, 2002 | 04:20 AM
hooptie157's Avatar
Default Re: what setup do you think will be more powerful? (Phoenix GSR)
what pistons are you running with the B20 bottom end?? Stock ITR pistons or B20 pistons?
Old May 20, 2002 | 04:45 AM
DC2_R's Avatar
Default Re: what setup do you think will be more powerful? (hooptie157)
hooptie I wanna point something out. You can not use stock ITR pistons in a B20 block. The bore of a B20 is 84 mm, versus the ITR of 81 mm. To answer the orginal question. The B20 with the ITR head would make the most power. I have seen dyno graphs from http://www.importreview.com showing some B20 VTEC motors putting any were from 217 stock to 240 with modifications. I am planning on building an CRVTEC myself. The choice is yours....
[Modified by JDM_EJ, 5:46 AM 5/20/2002]
Old May 20, 2002 | 04:52 AM
Hybrid ctr's Avatar
Default Re: what setup do you think will be more powerful? (JDM_EJ)
I would assume the B20 will make more power
Look at this chart, I know it has JUN 3's but it has a stock bottom end
kenney
Nov 23, 2008 04:24 PM
matty413
May 21, 2007 06:21 PM
JDM97EK
14
Mar 7, 2006 07:44 PM
cacahead1
Jan 31, 2006 07:26 PM
