1992 Acura Integra GS-R
Old Feb 15, 2007 | 05:27 PM
92integraVTECgsr's Avatar
Default 1992 Acura Integra GS-R
Make a REASONABLE OFFER. Lowballers will be ignored. I see people asking $4000-$5500 for all stock GS-R's and badly modified ones.
(Actual GS-R. Check the VIN DB2. I sold the B17 engine)
Tons of NEW Parts:
JDM B16 XSi 170hp Engine swap from Hmotorsonline.com bought and Installed in May 2006 (approx. 45,000 miles).
66,300 miles on the Engine and Transmission
265,300 miles on the Body
New Matador Red Paint (2005 Nissan Altima SE-R Red) Aug. 28/06
There was and is NO RUST or BONDO anywhere on the car.
Rota Slipstreams (16 inch)
Kumho Ecsta SPT Tires September 5, 2006
New Parts when engine was installed in May 2006.
• OEM Honda Timing belt, water pump, tensioner
• Exedy Stage 1 Clutch
• Integra TypeR Flywheel (resurfaced)
• Hondata Intake Manifold Gasket
• OEM Honda Valve cover & spark plug seals
• Distributor Cap & Rotor
• NGK Iridium Spark Plugs
• OEM Honda Spark Plug wires
• Exhaust Manifold Gasket
• Energy Suspension Motor Mount Bushing Kit
• RS*R ExMag Full Exhaust
• Carsound 2.25 Catalytic Converter
• Radiator
• Failsafe Low Temp Thermostat
• Brand New Napa Axles (not Remans)
• OEM Honda Transmission Axle Seal
• NGK Oxygen Sensor
Parts replaced as of Jan. 1, 2006.
• DC Sports 4-2-1 Header
• Tokico Illumina 5-way Adjustable Shocks
• Goodridge Stainless Steel Brake Lines
• PBR Metal Master Brake Pads
• Duralast Front Rotors
• Momo Tuner Steering Wheel
• Tekniq Quick Release Steering wheel hub (Best you can buy!)
• Tekniq Steering wheel hub
• Acura Integra Floor mats (Logo)
• H4H Super White Bulbs
Oil & Filter Changed every 3000 miles with Mobil 1 10w-30
AEM Cold Air Intake
Skunk2 weighted Shift ****
Skunk2 Short Throw Shifter
Eibach Prokit Lowering Springs
JDM 1 Piece Headlights
Ingals Camber Kit
New Sony CD Player July 06
Sony 3 way Front Speakers and Pioneer 3 way Rear Speakers
Fuel Filter
Tie Rods
Upper and Lower Ball Joints
Polyurethane Shifter bushings
Ignition Wires and Switch
Speedometer Cable
Apline 200watt 4-channel amp and 10 inch Lanzar Sub.
Rays Lug Nuts
Acura Integra Floor Mats (front)
A/C Charged and Blows Cold (had to wire a remote switch to engage the compressor clutch)
The car laid down 144.1 WHP but was told to add 13%, which comes to 162 WHP.
The engine DOES NOT burn or leak any OIL, or and other fluid. Only 93 Octane gas used.
Car is PERFECT! Nothing wrong at all. Pick up and drive anywhere! Very Clean!!!
Old Feb 18, 2007 | 06:26 PM
Default Re: 1992 Acura Integra GS-R (92integraVTECgsr)
bump
need to sell asap!
Old Feb 19, 2007 | 05:32 PM
up up and away.....
Old Feb 25, 2007 | 03:55 PM
Jezek.'s Avatar
Wow that's hella nice.....whish you weren't so far
Old Feb 25, 2007 | 07:11 PM
streetspeed607's Avatar
pmed
Old Mar 20, 2007 | 03:20 PM
DomesticDestroyer's Avatar
bump
Old Mar 20, 2007 | 03:32 PM
Default Re: 1992 Acura Integra GS-R (DomesticDestroyer)
do u have aim or anything?
Old Mar 29, 2007 | 02:56 PM
go250mph's Avatar
I just passed up one for $3000 same color -n- all. You need to at least have a starting price in here. Lots of peopl dont like to just toss an offer out there. Sweet car though.
Old Mar 29, 2007 | 03:01 PM
mra4886's Avatar
pm'ed you.
92integraVTECgsr
Jul 21, 2007 01:23 PM
92integraVTECgsr
Southeast (Sales)
Jun 29, 2007 09:19 PM
92integraVTECgsr
Southeast (Sales)
10
Feb 18, 2007 05:54 PM
92integraVTECgsr
Jan 7, 2007 04:58 PM
92integraVTECgsr
Sep 12, 2006 08:04 AM
