Fs or Ft: 1995 Talon AWD TSI w/99' eclipse conversion
The car is in good working condition. I have since moved to a new project that’s why I am selling the car. The asking Price of the car is far do to the fact that it is built and just needs some finishing touches. I have no time to work on the car. I must sell it as soon as possible. Ill take trades for a 96-00 Civic Hatch+cash if needed. The asking price for the car $8500 O.B.O. as is $8000 w/out wheels.
MOTOR & DRIVETRAIN
6 Bolt Swap
Lightened & Balanced Crank
2 G .20 over JE Pistons
1 G Rods
Balance Shaft Eliminator Kit
Race Port and Polished Head
5 Angel Valve Grind
1mm O.S. Valves
AEM High Flow Fuel Rail
550 cc Injectors
1 to 1 Fuel Regulator
Titanium Springs and Retainers
Ported 1 G Intake Manifold
Ported 2 G Exhaust Manifold
Ported 16 G Turbo w/34mm Waste gate Flapper
Ported O2 Housing
ARP Head studs
ARP Main studs
ARP Rod Bolts
Big Bore Lifters
High Flow Oil Pump
High Flow Water Pump
Stainless Steel Lines
ACT Racelite Flywheel
ACT Stage 2 Pressure Plate
ACT 6 Puck Race Disk
Stage 1 Transmission
Upgraded Axels
31x13x3 FMIC
Greddy Type S BOV
Turbo XS HPBC
Injen Intake
Thermal 3” Turbo Back Exhaust
Aluminum Radiator w/13” Spal Fan
Solid Motor Mounts
Solid Shifter Bushing
ELECTRONICS
Apexi Turbo Timer
5 “ Auto Meter Tach w/Shift Light
Oil, Boost, Air Fuel Gauges
Apexi SAFC 2 (Black)
Eclipse CD Player
Sony Explode Speakers
BODY & SUSPENSION
97-99 Eclipse Bumpers
Zennetti 19x8 Wheels
VIS Carbon Fiber Hood
Black Housing Projector Headlights
Tein Type Flex Coilovers
[IMG]
[/IMG]
MOTOR & DRIVETRAIN
6 Bolt Swap
1 G Rods
5 Angel Valve Grind
1mm O.S. Valves
550 cc Injectors
Ported O2 Housing
ARP Head studs
ARP Main studs
ARP Rod Bolts
Big Bore Lifters
High Flow Oil Pump
Upgraded Axels
31x13x3 FMIC
Greddy Type S BOV
Turbo XS HPBC
Injen Intake
Solid Motor Mounts
ELECTRONICS
Apexi Turbo Timer
Eclipse CD Player
BODY & SUSPENSION
[IMG]
[/IMG]
turbo-sohc 380WHP
Jul 31, 2008 04:39 PM
