WTB HARNESS BARS FOR AN EJ1
http://i50.photobucket.com/alb...7.jpg
kinda like that, but that's the concept. when using harnesses, the degree at which the harness connects to the car is usually at an angle. this is bad in an accident's situation. the reason why is because the crash will cause the harness to pull down on your spine due to it's weird angle. this is also called spinal compression, and it's very bad. in order to prevent this, you need to get harness bars so that the bars are straight when connected, and in the case of the crash, the harnesses won't pull down and you won't get spinal compression....
this is all from memory, but a thing or two in there might be wrong, but that's the basic concept.
BUMP
BUMP
Silvertc
Mar 8, 2013 12:02 PM
