Name that H22 game ^.-
Old Feb 14, 2007 | 04:37 PM
squarepusher's Avatar
Default Name that H22 game ^.-
and who the hell is Manny Fermin?
let the guessing begin!!! i dont have an answer either =] so its more of knowledge game =p
Old Feb 14, 2007 | 04:41 PM
.BigSexy's Avatar
most hood white kid
Default Re: Name that H22 game ^.- (squarepusher)
I know the only engine to come with a blue VC stock was the f20B(at least I believe so) but is there any other way to tell? looks like a regular h22 with an ugly *** VC
Old Feb 14, 2007 | 04:42 PM
poison's Avatar
Default Re: Name that H22 game ^.- (egcoupe94)
Are you serious?
Old Feb 14, 2007 | 04:46 PM
Default Re: Name that H22 game ^.- (poison)
lol, ya the guy i got it from had NO explanations, other than it was not stolen ... i have his drivers license information so I dont think he would pull that on me ... it came installed in the car already, and i dont know really what type of h22 it is o_O yes, pretty pathetic if you ask me =[
Old Feb 14, 2007 | 04:47 PM
SteveoBA8's Avatar
Bailing wire!
Old Feb 14, 2007 | 04:57 PM
EKHWhat's Avatar
Haha, what the hell is the point of the wire on the motor mount bolt going to the timing cover? Haha.
Looks like a normal H22 to me. No way to tell really unless you ckeck the internals out.
Old Feb 14, 2007 | 04:58 PM
2lude4u's Avatar
Default Re: Name that H22 game ^.- (SteveoBA8)
I wonder if the engine was built, so the engine builder put the owner's name on the block (on the stamp, rather than with a marker) to keep it straight? Or maybe it's the engine builder's name.
Otherwise that's the gayest thing someone could do to their engine.
Old Feb 14, 2007 | 05:00 PM
EKHWhat's Avatar
The distributor appears to be internal coil.
If so, at least the distributor is off of a JDM H/F series motor.
But then again, It's got the M2S4 Prelude Si (H23A1) transmission.
Mayby it's a H23?
Mayby it was built for boost, once boosted running the H23 transmission, and now it's no longer boosted.
Ckack it upen and check wherything out man. Easiest thing to do is to check the cam specs. probabally.
Or not worry about it as long as it runs.
nonvteclude's Avatar
Default Re: (EKHWhat)
looks like its to make sure he doesnt loose the flywheel checker plug. how the hell did that manny do that and why would he?
Old Feb 14, 2007 | 05:03 PM
.BigSexy's Avatar
most hood white kid
tranny says its an M2S4...anyone know what tranny that is?
Old Feb 14, 2007 | 05:08 PM
EKHWhat's Avatar
Default Re: (egcoupe94)
H23A1 prelude Si transmission.
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">I know the only engine to come with a blue VC stock was the f20B(at least I believe so) but is there any other way to tell? looks like a regular h22 with an ugly *** VC</TD></TR></TABLE>
That's not a stock Valve cover and the H23A VTEC engine had a Blue Valve Cover stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u &raquo;</TD></TR><TR><TD CLASS="quote">I wonder if the engine was built, so the engine builder put the owner's name on the block (on the stamp, rather than with a marker) to keep it straight? Or maybe it's the engine builder's name.</TD></TR></TABLE>
^^What came to mind also..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">tranny says its an M2S4...anyone know what tranny that is?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKHWhat &raquo;</TD></TR><TR><TD CLASS="quote">But then again, It's got the M2S4 Prelude Si (H23A1) transmission.</TD></TR></TABLE>
^^Correct
Looks like you have some disassembling to do to figure it out.. Check out the stamps on the Cly. Head. Might come to a conclusion with those.. Also, what Tensioner does it have? Auto or Manuel? Might help..
Old Feb 14, 2007 | 05:12 PM
EKHWhat's Avatar
Well whether it has the auto or manual tensioner, that wouldn't officially prove that it was a H23/H22.
The motor has obviously been modified, and anyone who has any since of modifying a prelude knows that the H23 tensioner is the way to go if they have to replace the tensioner. So even if it did have the H23 tensioner, that wouldn't officially prove it. If it's got the auto tensioner, chances are that it's some kind of H22.
Again, no way to tell unless you look at the internals.
MLBZ521's Avatar
Oh and.. That looks like a custom number under the name..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by squarepusher &raquo;</TD></TR><TR><TD CLASS="quote">Manny
Fermin
00127</TD></TR></TABLE>
But if you look, at least to me, there's a " 1 " like mark to the side of the name.. Is that a mark/cut like an H22A1 or H23A1 motor? Or am I seeing things??
Old Feb 14, 2007 | 05:13 PM
CGags13's Avatar
its a stock H22...whoever the hell that guy is you can see he grinded H22 off and stamped his nombre and that number in (look how clean that area is)...
looks like this engine is in a civic...did you buy this car with it swapped in?
Old Feb 14, 2007 | 05:17 PM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKHWhat &raquo;</TD></TR><TR><TD CLASS="quote">Well whether it has the auto or manual tensioner, that wouldn't officially prove that it was a H23/H22.
Again, no way to tell unless you look at the internals.</TD></TR></TABLE>
^^Yeah, didn't mean it was going to be a definite answer, just a possible hint.. As I dout someone would put the Auto onto an H23, so.. If it is Auto, it would probably be an H22.
And I agree on opening it up to see the internals.. Just could remove the Cly. Head and see if it's open or closed deck also.. Because that's a easy way to find out..
Interesting though..
Old Feb 14, 2007 | 05:20 PM
ethereal2pt2's Avatar
Default Re: (CGags13)
maybe it's just me but that paint doesn't look oem.
Old Feb 14, 2007 | 05:33 PM
MLBZ521's Avatar
Default Re: (_BB6)
^^It's not... The Letters aren't painted with OEM either..
Also, if you notice, OEM Valve Covers have that gritty look and feel to them, and normally when someone gets a Valve Cover painted it is not longer gritty, but smooth.
Old Feb 14, 2007 | 05:35 PM
preludeguy_92's Avatar
Default Re: (_BB6)
No thats spray paint
Old Feb 14, 2007 | 05:38 PM
CGags13's Avatar
its a h22...how can you fit a h22 cover on an h23 head??
Old Feb 14, 2007 | 05:39 PM
.BigSexy's Avatar
most hood white kid
Default Re: (MLBZ521)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">
like I said, I wasn't too sure, I knew the f20b had a blue VC, but wasn't sure about anything else. It looks like an h22 VC painted blue to me
Old Feb 14, 2007 | 05:42 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 &raquo;</TD></TR><TR><TD CLASS="quote">its a h22...how can you fit a h22 cover on an h23 head??</TD></TR></TABLE>
who said it was an h23?
Old Feb 14, 2007 | 05:46 PM
MLBZ521's Avatar
No no... H23 Bottom end, and H22 Cly. Head..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">like I said, I wasn't too sure, I knew the f20b had a blue VC, but wasn't sure about anything else. It looks like an h22 VC painted blue to me</TD></TR></TABLE>
Yep yep! Sorry didn't mean to sound like you were wrong..
I'm not sure exactly what the F20B and the H23A VTEC Valve Covers look like and I'm not sure if they'll fit on an H22 either..
Old Feb 14, 2007 | 05:48 PM
CGags13's Avatar
oh haha im gay for not reading it....anyway heres a hint about f20b dohc heads...dc would never make a header to fit them...the stock f20b valvecover is powdercoated blue and looks just like a h22 one...
Old Feb 14, 2007 | 05:53 PM
MLBZ521's Avatar
Ah yes, I didn't even think about the DCSport Header... But would another F-Series DCSport Header fit on the F20B though?
Yeah, the H23 VTEC is powdercoated the same way I believe, but I don't know if the wording/placement of the wording is any different. Also the Valve Cover Cap.. I know USDM H23A1's are on the right side instead of the left.. (Depending on your viewing pleasure/angle..)
But being gay for not reading something is kinda harsh isn't it?? No reason to bash yourself..
