H22A Balancer shaft pully?
Old Feb 14, 2007 | 04:02 PM
EKHWhat's Avatar
Default H22A Balancer shaft pully?
Is there a TDC mark for the rear balancer pully on a H22A?
Also-What could be the worst thing done to my motor if it was ran without the balancer shaft belt on it? I got the motor like this and i'm afraid it may have been ran like this.
Old Feb 14, 2007 | 04:08 PM
fastlude69's Avatar
you got to take the bolt off the rear of the block and put a long 10mm bolt or phillips screw driver through the hole. in the rear balence shaft
Old Feb 14, 2007 | 04:28 PM
EKHWhat's Avatar
Why? I noticed this somewhere, but I didn't have the huge-*** allen key I needed.
Anyone know what size it is?
Old Feb 14, 2007 | 04:48 PM
MLBZ521's Avatar
Default Re: (EKHWhat)
Ah, I forgot what the TDC mark looks like, if it has one, which I do think it does...
But running with out the Balancer belt is fine, no problems. A lot of people cut or remove it to create less drag, and it's easier than removing the balancer shafts with the motor in the car..
^^If I'm wrong.. Fix it.. Heh
I'll look for the picture of the TDC mark though..
Old Feb 14, 2007 | 04:55 PM
EKHWhat's Avatar
Alright thanks.
I sure as hell don't see one.
Old Feb 16, 2007 | 01:36 PM
nikolai.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKHWhat &raquo;</TD></TR><TR><TD CLASS="quote">Why? I noticed this somewhere, but I didn't have the huge-*** allen key I needed.
Anyone know what size it is?</TD></TR></TABLE>.
You are looking at the wrong bolt.
rasta420
Jan 3, 2007 11:09 AM
typemismatch
Oct 12, 2004 06:11 PM
SleeprCivic
Jun 25, 2003 01:01 PM
satan_srv
Nov 21, 2002 02:15 PM
