Parting Turbo LS - BMC Log - Head lights - Motor mounts - WHOLE CAR PART OUT
Old Feb 14, 2007 | 04:01 PM
jfoster's Avatar
Default Parting Turbo LS - BMC Log - Head lights - Motor mounts - WHOLE CAR PART OUT
Parting out a '94 LS turbo Integra.
BMC log mani $145 shipped OBO
Cracked and repaired about 5k miles ago
Mitsu turbo flange
** SOLD rSX4u2NV ** '94-97 Head Lights. Lenses are yellowed/brittle/aged looking ... but work fine. Perfect for someone with good lenses needing good housings. $50 OBO
*Power steering torque mount sold to 92civichatch1 *
* UPPER TRANNY SIDE MOUNT SOLD**
Motor mounts. (2) upper, (2) lower with inserts, (1) Rear/main *NOT PICTURED* I am fairly certian I have the insert for the rear as well unopened.
EDIT: PULLED THE REAR AND FOUND INSERT - Mount is torn but includes brand new insert :6
Starter $50 shipped
EDIT: MORE STUFF
** Axles pending pick up on tuesday***
*Intermediate shaft sold to 92civichatch1 *
MaxSpeed sleeve style coil overs (set of 4) $50 shipped , axles , intermediate shaft , Bilstein front shocks (pair) $75 shipped
Cluster $30 shipped
*Pending pick up on tuesday* Hydro LS trans - one damaged threaded bolt hole (pictured) works fine as is or buy a bell housing section for ~$50 . Price = $200 + S&H ~80lbs
Hatch / glass / lighted wing
*SOLD to poorman's type-r Omni Power sleeve style coil overs (set of 4) under 2k since new $100 + S&H
Need something ?
Lots of other stuff coming soon. Including:
After market clutch
Wiring harness
Any suspension / brake components
Omnipower sleeve style coil overs
Steering rack
Suspension sub frame
Wind sheild
Hatch with glass
Ignition, door and hatch tumblers w/ matching key
tan dash
cluster
window glass
Core support and/or frame sections
NAME IT !!! If I can pull it or cut it off I'll sell it
Modified by jfoster at 11:39 PM 2/22/2007
Old Feb 14, 2007 | 04:39 PM
jfoster's Avatar
Default Re: Parting Turbo LS - BMC Log - Head lights - Motor mounts - WHOLE CAR PART OUT (jfoster)
Also
Socketed & chipped OBD1 P75 ECU $100 shipped
Exedy Stage II Clutch . Probably 5K miles in a sub 250whp car $300 Shipped
Should fit all hydro B series
Old Feb 21, 2007 | 02:06 PM
jfoster's Avatar
PMs replied
BUMP for more stuff
Motor mounts are $35 shipped each or buy remaining 4 for $120 shipped inserts included.
jfoster
Sep 10, 2009 07:53 PM
jfoster
Sep 10, 2009 07:47 PM
jfoster
Aug 18, 2008 05:44 PM
