Okay guys, Wont start need help:) New car
Old Feb 14, 2007 | 03:18 PM
s_vares's Avatar
Default Okay guys, Wont start need help:) New car
Hi, my name is steve and im brand new to prelude's so excuse my ignorance
I just bought a 1997 2.2 vtec
I bought it with a wrecked quarter panel from the old scrap yard clear title.
Had to be towed to my house as it wont start, yet it ran fine in the yard.
Car has spark, im using the proper key, has fuel.
will only crank. The yard thought it was the starter/alarm when it wouldnt go so they removed it. still no go.
ANy help would be great
Thanks
Steve
Old Feb 14, 2007 | 03:58 PM
flyrod's Avatar
Default Re: Okay guys, Wont start need help:) New car (s_vares)
when you turn the ignition on does the CEL come on then go back off? can you hear the fuel pump come on?
Old Feb 14, 2007 | 04:17 PM
s_vares's Avatar
Yeah, engine light on then off
fuel pump runs. we check spark it there
im rattled
Old Feb 14, 2007 | 04:23 PM
prelude1897's Avatar
Default Re: (s_vares)
you're postive it's getting spark? What about the starter connections? I'd take the starter up to Auto Zone and have it tested. What about the battery? Try jumping the car and see if that does anything. Just start off with the simple things and then move up from there
Old Feb 14, 2007 | 06:30 PM
flyrod's Avatar
pull the the fuel supply hose off the rail and put the end in a jar. turn the ignition on and you'll get a couple cups of fuel in the jar. see if it has water in it.
Old Feb 14, 2007 | 06:46 PM
M2B4's Avatar
Default Re: (flyrod)
i say check ur plugs. make sure there not fouled. mine did that 1 day fine next fouled
Old Feb 14, 2007 | 07:01 PM
Revi's Avatar
Default Re: (M2B4)
If it turns over its not the starter, how is the battery? Ive had cars before where they would turn over but they would not start. Swaped in a new battery and kicked like a muel. Have you tried a new/different battery?
Old Feb 16, 2007 | 07:21 AM
s_vares's Avatar
mechanic came out and said the motor should start. He said the imobilizer is working but thinks its the remote starter bypass bunging it all up.
Im going to remove it and reattach the cut wires for it and see!! cross your fingers for me
Steve
lif3tak3n
Jun 24, 2014 06:00 AM
JDM Freakk
Jun 21, 2011 05:36 PM
jdmda_1.7a
Nov 4, 2010 04:57 PM
yahboyryan
Mar 13, 2008 06:12 PM
alfee
Apr 4, 2005 07:03 PM
