really lose shifting.
Old Feb 14, 2007 | 01:51 PM
dohc_profile's Avatar
Default really lose shifting.
ok short shifter, replaced shifter stabilizer bushings, now the problem. shifter worked better than the day it rolled off the line...till emissions. the garage owner took my car in did the test, then parked it outside i went out after just BARELY passing..(P.S. if ur going for emissions, put about 2-3 shot glasses worth of 100%acetone in ur tank. thats wut got me through, anyways) now the shifter is really lose..goes into gear fine...but moves ALOT in nuetral, and way too much when in gear, any ideas? moves as in i can shake it.
Old Feb 14, 2007 | 02:12 PM
tougetuned_ef's Avatar
Default Re: really lose shifting. (sohc_mnstr)
it will move a little no matter what. but check to make sure the bushing are fine.
Old Feb 14, 2007 | 02:17 PM
91ed9's Avatar
check the bushins on the tranny
and also righ by the shifter
(on the shift linkage)
mine does the same
Old Feb 14, 2007 | 02:27 PM
how much does it move? im talkin its goes atelast 5 inches lef tor right while in gear and nuetral is ridiculous all the bushings seem to be fine...i cant figure it out
Old Feb 14, 2007 | 05:43 PM
bump
Old Feb 14, 2007 | 05:48 PM
dr_latino999's Avatar
Default Re: (sohc_mnstr)
I know the answer because I'm good like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Me &raquo;</TD></TR><TR><TD CLASS="quote">
In my Sedan my shifter has such much side to side play it is funny; I'm talking you can take out people's knees when you go over to fifth. After doing some research I found I need to replace the bushing in the shift linkage (54201-SH3-A04), and thank the lord the linkage is only 37.04 from the dealer.</TD></TR></TABLE>
Old Feb 14, 2007 | 05:50 PM
hmmm im noticing a pattern, this is the second time you've bailed me out lol. thanks dr_latino. any chance u sould show me where this bushing is? and how to change it?
Old Feb 14, 2007 | 05:53 PM
Well the alternative name for this bushing is the whole shift linkage.
The bushing is circled in red, the whole shift linkage (#14) needs to be replaced and that's the part number I provided.
Old Feb 14, 2007 | 05:54 PM
ok, im surprised its thats cheap. thanks for your time
Old Feb 14, 2007 | 05:55 PM
Same thing I said when I saw the price, I pitty the swap people who have to dish 130+ for these things.
Old Feb 14, 2007 | 10:49 PM
digitally_remastered's Avatar
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">In my Sedan my shifter has such much side to side play it is funny; I'm talking you can take out people's knees when you go over to fifth. After doing some research I found I need to replace the bushing in the shift linkage (54201-SH3-A04), and thank the lord the linkage is only 37.04 from the dealer.
ok so if thats for the linkage, how much just for the bushings?? are just the bushings replaceable instead of the whole linkage?? that explains why mine is the same way as sohc_mnstr...
Old Feb 15, 2007 | 03:51 AM
the1337aaron's Avatar
i have this same problem riht now and its cuz the previous owner rigged my linkage up with a screw and not the bitch pin. the screw is smaller than the size of the hole so i gots lots of play in my shifter. the pin may have fallen out on yours?
Old Feb 15, 2007 | 04:26 AM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Same thing I said when I saw the price, I pitty the swap people who have to dish 130+ for these things.</TD></TR></TABLE>
I pitty the d series people when i pass them,
Also part number 8 took a **** in my linkage taht can cause a loose shifter too
Old Feb 15, 2007 | 05:58 AM
Default Re: (digitally_remastered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitally_remastered &raquo;</TD></TR><TR><TD CLASS="quote">
ok so if thats for the linkage, how much just for the bushings?? are just the bushings replaceable instead of the whole linkage?? that explains why mine is the same way as sohc_mnstr... </TD></TR></TABLE> If you can figure out a way to replace the bushing in the joint, go ahead but NO ONE sells it seperately.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">I pitty the d series people when i pass them, </TD></TR></TABLE> I pity the B-Series People when I pass them getting 38mpg
Old Feb 15, 2007 | 10:26 AM
ok thanks for telling me that lol. i havent done much with hondas yet, just a tranny swap that the tranny failed on me, and a mpfi swap. so the linkage piece as a whole is 35 bucks, that isnt to bad of a deal. but im sure someone has a good one that they no longer need because they went to a b series....ill have to hunt for one then. thanks.
Old Feb 15, 2007 | 02:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> If you can figure out a way to replace the bushing in the joint, go ahead but NO ONE sells it seperately.
I pity the B-Series People when I pass them getting 38mpg </TD></TR></TABLE>
Thats it?i use to get 50 mpg in my d, i have gotten high 30s in the b16a with 14 psi
Old Feb 15, 2007 | 03:03 PM
instead of creating another thread..how about i extend my issues in this one. when driving in any gear including nuetral i hear and feel a knocking underneath my clutch pedal. the sound goes away when i apply brakes. it only goes away when accelerating and braking. i was using the highway to get home and the car was shaking at highspeeds. my mechanic mentioned i need new axles soon, and my driver side axle popped out recently. could this knocking be a result of a bad axle?
Old Feb 15, 2007 | 05:08 PM
91ed9's Avatar
yes but it would probably click onn tunring also ... is this also happeneing?
Old Feb 15, 2007 | 05:18 PM
TH33G4MON3's Avatar
Default Re: (91crx Si)
When my shifter was super loose I just rechecked everything and found that some things were kinda loose, tightend them up and it was perfect.
But this was also after buying brand new shift linkage and a new short shifter...
paid $110 or $120 for my shift linkage. Got mine off of Passwordjdm.com
Old Feb 15, 2007 | 07:43 PM
i dont really notice it when im turning
EF9_TryMe
11
Nov 14, 2008 12:02 AM
---SPEED-DEMON---
Sep 16, 2008 09:18 AM
DirTyPreTTyThinGs
Aug 15, 2007 08:35 PM
invasian_boy
May 15, 2007 09:24 AM
tomato_man
10
Apr 15, 2007 06:56 PM
