Difference in JDM H23 Vtec and USDM H22?
Does anyone know what the difference is in the JDM H23 vtec and the USDM H22? Can I use the same rods as the H22 and and 87mm pistons? Does anyone know where to get specs on H23 vtec? Thanks.
Thanks!
But, that really doesn't answer my questions. I need to know if the bore and stroke are the same on H22 and H23....
[Modified by Sushi X, 5:39 AM 5/20/2002]
But, that really doesn't answer my questions. I need to know if the bore and stroke are the same on H22 and H23....[Modified by Sushi X, 5:39 AM 5/20/2002]
anyone? I'm thinking since the crank is different I would have to go with different rods, but can I use the non vtec H23 rods? Anyone???
i'm not sure, but i think the jdm h23vtec is just the h22 w/h23 crank and rods. i know that can be done, the deck hight is the same. also talk to "rocketlude" on http://www.hondaprelude.com , he has this setup running 25 psi. making 550+whp!
jdm knight
Mar 29, 2006 06:43 AM
comparison, difference, differences, fs, h22, h22a, h23, h23a, h23vtec, jdm, rods, specs, usdm, vtec, vtech
