removing the power steering?
Old Feb 14, 2007 | 11:12 AM
accordinglyevil's Avatar
Default removing the power steering?
what is the best way to remove the power steering unit without making a big mess. my power steering is leaking and i'm going to replace it myself, but i can't find a place to drain the fluid out without making a big mess.
Old Feb 14, 2007 | 07:15 PM
hondadude's Avatar
Default Re: removing the power steering? (accordinglyevil)
P/S pump? or P/S rack?
those old 79s are really easy to work on.
Old Feb 14, 2007 | 09:00 PM
Default Re: removing the power steering? (hondadude)
power steering pump on my 99 accord.
Old Feb 15, 2007 | 02:54 PM
Accord2k-Hybrid's Avatar
the best method I found was to rig a bottle to stay up with a funnel in it directly under the reservoir.
Slowly remove the bottom hose from the reservoir and wait for the fluid to drain, you'll get a little messy, but if you're careful enough it should be a fairly clean job.
if you're removing the pump, just make sure to have a few rags as you remove the lines from it to soak up the fluid as you take them off.
Stevo F
May 5, 2014 05:30 PM
EM2_touge
Honda Civic (2001 - 2005)
20
Jun 20, 2009 02:49 PM
spintboy
Feb 23, 2008 10:30 AM
Ross
Jun 18, 2002 02:17 PM
