sohc 1.7 crank
hey i got a newer 1.7 civic crank and i am going to put it in my 1.6 sohc zc block its been done before but i need the "how to guide" for all the little stuff and what i need to make it work
the D17 uses a different oil pump due to larger diameter snout - you would need to use D17 pistons as the D16 pistons would be 1.3mm above the top of the block - using D17 pistons with D16A6 head is going to drop the compression ratio down to around 8.8:1
