pounding out the inner fender wells?
Old Feb 13, 2007 | 09:30 PM
Jdmsolutions's Avatar
Default pounding out the inner fender wells?
ive been reading that you need to pound out the inner fender wells on ef hatches so the upa will be able to travel once my car is dumped? anybody have a picture or something? im rather confused kinda... or jsut any advice?
Old Feb 14, 2007 | 01:59 PM
Default Re: pounding out the inner fender wells? (Jdmsolutions)
help me guys!!!
Old Feb 14, 2007 | 03:13 PM
EF001282's Avatar
I think you mean to get you fenders rolled, you can use a baseball bat (the cheap way) or you can have a body shop do it for you or you can get a fender roller from Eastwood.com look for it here http://www.eastwoodco.com/shop...31158
Old Feb 14, 2007 | 03:19 PM
janz3n's Avatar
Default Re: pounding out the inner fender wells? (EF001282)
i dont think he means rolling the lip.. because he wrote upa which im assuming he means upper control arm. iv seen pictures of the shock tower with a cut in it so the upper control arm would go even higher.
Old Feb 16, 2007 | 02:50 PM
Default Re: pounding out the inner fender wells? (janz3n)
yeah i was talking about the upper control arm... i jjust dont wana start cuting or pounding if there is a way around it..
Old Feb 17, 2007 | 04:20 AM
TheCheeseWedge's Avatar
youll only need to bend in the fender seam if you have a camber kit and are low otherwise you should be fine. i used a nice deadblow hammer to do mine
Old Feb 19, 2007 | 01:48 PM
Default Re: (TheCheeseWedge)
cool how far did you have to pound? and what chamber kit did you use?
Old Feb 23, 2007 | 01:00 AM
Default Re: (Jdmsolutions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmsolutions &raquo;</TD></TR><TR><TD CLASS="quote">cool how far did you have to pound? and what chamber kit did you use?</TD></TR></TABLE>
i made the fender seam flat for majority of the top portion on the inner fender and i used an engles camber kit I also rolled my fenders with a baseball bat(old school hot rod trick)
Old Feb 23, 2007 | 10:54 AM
sounds great man... does it make the inside of the engine bay look stupid?
Old Feb 23, 2007 | 12:58 PM
ypu cant see it from the engine bay its on the otherside in the fenderwells lolkinda on the frame
wdissident
13
Aug 16, 2021 02:56 AM
usdm_ED7
Dec 19, 2010 10:00 PM
OBDII Integra
Jul 19, 2009 09:41 AM
95sloweg
May 4, 2008 06:31 PM
drjondurst
Jan 28, 2003 10:36 AM
