DA master cylinder ? please help
Old Feb 13, 2007 | 07:59 PM
HFpower's Avatar
Default DA master cylinder ? please help
i have a 91 HF with D16a6 i just swapped the brake booster to a DA booster and master cylinder but only 1 hose fits and the other is to small has anybody incountered this problem pease tell me how u solved it thank
Old Feb 13, 2007 | 08:39 PM
HFpower's Avatar
Default Re: DA master cylinder ? please help (HFpower)
please any info would be great
Old Feb 13, 2007 | 08:42 PM
yz125rider21's Avatar
129 threads about this
https://honda-tech.com/zerosearch
Old Feb 13, 2007 | 08:57 PM
92civicfreak's Avatar
i know it... your problem is that you have a master cylender from an ABS DA intagra... i'm sry to say the only way to make this one work is to get that one fitting... u will have to cut your stock hose & then put the bigger fitting on & then reflare it... OR go to your local junkyard & pick a NON-ABS one
Old Feb 13, 2007 | 09:07 PM
HFpower's Avatar
Default Re: (92civicfreak)
92civicfreak thanks alot for your help i shall go to the junk yard tomarrow and pick up a non abs master cylinder
Apr 5, 2018 11:34 AM
twentyhurtz
Suspension & Brakes
Oct 13, 2008 05:12 AM
9112
Nov 30, 2007 07:29 AM
roadrunner1
19
Feb 28, 2007 07:44 PM
adrian1281
Aug 23, 2003 09:43 PM
