Pic Request Rear Trunk Brace and Rear Panel
I have a ITR rear trunk brace that I am mounting on a non- Type R. The non Type R bodies do not have the mounting holes. I want to mount the trunk brace exactly the way it is mounted on a Type R. Please post detailed pictures of the brace on the inner trunk wall. Possibly some pictures of the trunk without the panel and the bar installed so I can see the hole placement.
I work in a salvage yard and a 94 gsr came in with the bar installed and the mounting holes were there. If not, there should be the same holes on the trunk floor, about 4" from the spare tire well.
I found one picture in a rebuild thread, It looks like the rear panel is trimmed for the bar, but I need a more detailed picture.
What Ive seen people do is drill the hole where its suppose to be and put a locking nut on the other side
I know there is a post about it but no clue where it is
My GSR.
https://honda-tech.com/zerothread?id=1667154
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrdave »</TD></TR><TR><TD CLASS="quote">My 97 GSR had the mounting holes - what do you have that doesn't have the holes ???</TD></TR></TABLE>
No you're probably mistaken by the child seat anchor points. Can't use them to mount the trunk brace.
I ordered some M8 Nut rivets from mcmaster.com today. Only $5 for a pack of ten. The tool is the expensive part but I have one at work! The part number is 95105A191
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo »</TD></TR><TR><TD CLASS="quote">What Ive seen people do is drill the hole where its suppose to be and put a locking nut on the other side
I know there is a post about it but no clue where it is</TD></TR></TABLE>
so is it actually fastened to something with strength or just some sheet metal?
kommon_sense
23
Jan 6, 2012 07:36 AM
