5th Gen Anyone's experiences with a 17x7 42mm offset
Old Feb 13, 2007 | 07:09 PM
king_friday16's Avatar
Default 5th Gen Anyone's experiences with a 17x7 42mm offset
I'm new and I want to hear people's experiences with 17s and a low drop, since I keep hearing 17s FTW so I decided to go with 17s. I'm not asking anyone about what good sizes of rims, offset and lowering because I already saw a thread on do's and don'ts for tires and wheel sizes on 5th gen ludes. I know that 42mm offset on a 17x7 with 215/40/17 tires is a gray area and that 45-50mm is recommended for lowering. I'm planning on getting 17x7 with a +42 offset with 215/40/17 tires, but I wanna know how low I can drop my Skunk2 coilovers. Can I get the car low enough to tuck the tires in just a little bit without any rubbing. When I bought the car, the owner had 18s but he sold me the car with the stock wheels instead , but the rear fenders are already rolled.
Old Feb 13, 2007 | 07:12 PM
M2B4's Avatar
Default Re: 5th Gen Anyone's experiences with a 17x7 42mm offset (king_friday16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">copied from: http://www.ottawaprelude.ca/ya...=2886
OFFSET:
6.5" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: You take the chance of rubbing the outside lip of the wheel well.
+38mm to +55mm ::: You shouldn't have any problems. Recommended Offsets for 6.5" Wide Wheels.
Larger than +55mm ::: You take the chance of rubbing the inside lining of the wheel well.
7" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: Not Recommended
+38mm to +41mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well.
+42mm to +44mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well.
+45mm to +50mm ::: You shouldn't have any problems. Recommended Offsets for 7" Wide Wheels.
Larger than +51mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
7.5" Wide Wheels w/ 4th & 5th Gen
Less than +40mm ::: Not Recommended
+40mm to +43mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using any tire with an overall diameter larger than stock and/or with a tire width larger than 215.
+44mm to +47mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using a tire with an overall diameter more than slightly larger than stock, you chances of rubbing increase.
+48mm to +52mm ::: You shouldn't have any problems. Recommended Offsets for 7.5" Wide Wheels.
Larger than +53mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
8" Wide Wheels w/ 4th & 5th Gen
Not recommended without enlarging or rolling outside lip of wheel wells. Some people have had success with running offsets larger than +48mm, but you are taking an expense risk.
Old Feb 13, 2007 | 07:15 PM
Default Re: 5th Gen Anyone's experiences with a 17x7 42mm offset (M2B4)
-That is a vague answer, I want to hear a legit direct answer which is why I'm asking about experiences.
Old Feb 13, 2007 | 09:32 PM
Bump
ls1tjw
Jan 24, 2007 05:02 PM
mlow634
Dec 16, 2006 02:31 PM
ej2_sir
Sep 11, 2006 08:04 AM
lakerschamp2000
Nov 28, 2005 03:33 PM
spangler
May 22, 2002 09:53 AM
