Honda S2000 Honda S2000
stock caliper question
Old Feb 13, 2007 | 03:47 PM
TL1000R's Avatar
Default stock caliper question
Can anyone verify weather the stock s calipers are made of steel or aluminum?
Old Feb 13, 2007 | 04:12 PM
TL1000R's Avatar
Default Re: stock caliper question (TL1000R)
anyone?????
Old Feb 13, 2007 | 04:27 PM
LAS2K's Avatar
there was a thread floating around here about 6 months ago that had tons of s2k brake info...i'll try and dig it up.
Old Feb 13, 2007 | 04:33 PM
LAS2K's Avatar
Default Re: stock caliper question (LAS2K)
If i were to guess, which i am, it is made out of aluminum. Nissin makes spoon calipers which are aluminum and nissin is also the manufaturer of our calipers. why?
Old Feb 13, 2007 | 04:36 PM
Mr. Projekt's Avatar
* B A N N E D *
Cast aluminum sliding calipers.
Old Feb 13, 2007 | 05:08 PM
TL1000R's Avatar
I'm going to start grinding my calipers smooth before I hi-temp paint and clear them and I want to do it a little at a time. Grind one weekend and paint when it gets a warmer outside to cut down on down time. thanks for the input.....
Old Feb 13, 2007 | 05:09 PM
TL1000R's Avatar
Default Re: stock caliper question (Mr. Projekt)
I knew if you were around you would have an answer for me. thank you
Old Feb 13, 2007 | 05:16 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R &raquo;</TD></TR><TR><TD CLASS="quote">I knew if you were around you would have an answer for me. thank you</TD></TR></TABLE>
If you want that high-temp paint to stick even better, use a galvanizing primer. Spray can.
Old Feb 13, 2007 | 05:19 PM
revhi's Avatar
Powder coat them. I had my rears done.
Old Feb 13, 2007 | 06:05 PM
TL1000R's Avatar
will do! thanks...........
lickety_britches
Sep 30, 2007 06:25 PM
spock_rocker
Mar 15, 2005 03:20 PM
LankorDie
Jun 14, 2004 03:20 PM
RStoR
Honda S2000
Oct 2, 2003 08:21 PM
Big Teggie
May 7, 2003 06:50 PM
