VTEC speed check
The speed check you don't mean the 12 mph or so needed as one of the requirements to X over....
If so I really don't like where this is going LOL.
Are you maybe speaking of the top speed governer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NegativeXero »</TD></TR><TR><TD CLASS="quote">Is there any way to disable the VTEC speed check without a tuning program such as Uberdata or Hondata? If there is, how would i go about doing that? </TD></TR></TABLE>
explain yourself
explain yourself
He is talking about what the vss reads to tell the ecu that the car is over the certain mph then to engage vtec i dont think there is a program for that but im not for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oodie »</TD></TR><TR><TD CLASS="quote">He is talking about what the vss reads to tell the ecu that the car is over the certain mph then to engage vtec i dont think there is a program for that but im not for sure.</TD></TR></TABLE>
Vtec when parked SWEET
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicEX »</TD></TR><TR><TD CLASS="quote">why would you want to do that?</TD></TR></TABLE>
Didn't you read my post?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max The Amazing »</TD></TR><TR><TD CLASS="quote">
Vtec when parked SWEET </TD></TR></TABLE>
noooooo.
what i'm saying is.
my VSS doesn't work. so my speedo doesn't work. so ultimately my VTEC doesn't work. So what i'm asking is there anyway to jump the ecu so that it doesn't check for the 8mph needed to engage VTEC? I know there's a way to jump the ECU for VTEC oil pressure, so there must be a way to do this.
what i'm saying is.
hmm.....i dunno how that works, because VTEC must have a certain speed registered before it engages, and my VSS is bad...i just don't know what to do. I need to find a way so that it doesn't require a speed check to engage VTEC.
I pretty sure that there is no way around that the ecu has to have the vss to engage vtec are the ecu connections good if so try another ecu and if that dosent work your going to have to replace vss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">you can get your ecu chipped, </TD></TR></TABLE>
You could but...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Looks like you just have to wait until your VSS gets replaced. Don't half-*** something just to get VTAK y0.</TD></TR></TABLE>
You could but...
junk yard for vsss
or you can go to like majestic or hondareplacementparts or osmethign like that
find someone on H-T see if they have a spare that have done swaps
but yeah its most likely the vss not the ecu...
