running out of ideas here ,with my 99 swap NEED HELP PLZ
info
99 cx civic 3d
94 gsr full swap (obd1 dizzy ,obd1 alternator , obd2 inj)
99 civic ex engine wire harness (one pice) with obd1 jumper harness
try 3 ecu's allready (jdm p72,usdm p72, p09)
brand new main relay from honda
it cranks but the fuel pump is not priming , nor the main relay is clicking or spark
i check all my grounds of my engine and nothing , what could be the problem today i bought a brand new main relay from honda and nothing check all my fuse and all of them where fine bu one #31 was not getting power
thanks
plz help
thanks
99 cx civic 3d
thanks
plz help
thanks
get a wireing diagram and following the power side for your main relay..i did the same swap b4 (obd2 car with obd1 motor) i had the same problem with the not starting but my problem was not enough grounds for the relay to work properly...the first things to check are fuel and spark so start there and good luck
EK FLY
Feb 25, 2007 04:36 PM
EK FLY
Feb 9, 2007 01:48 PM
EK FLY
Jan 28, 2007 06:52 PM
