HFP suspension, STS class?
I assume you are starting in stock?
Anything that changes the springs will bump you from stock. I am not familiar with what the HFP suspension is, but any type of sport or lowering spring or coil-over will put you in STS, provided you haven't done any other mods that bump you higher.
I would still put you in STS if I was doing the tech inspection. Stock will allow upgraded suspension that is correct for a particular model (i.e. if an Si came with stiffer springs or something), but an add-on part that is not stock for the car, no matter the trim level, would bump you up a class.
no prob.
You can actually get the electronic copy of the SCCA rules here for free if you want:
http://scca.com/_FileLibrary/F...s.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MattP »</TD></TR><TR><TD CLASS="quote">That's correct. Despite the name, the HFP package is dealer installed and thus is not legal for stock class.
I believe the new Si would be in STX, since it comes with an LSD.</TD></TR></TABLE>
I looked at the rule book and it said Im G Stock class but also STS/STX eligible or something like that. (Page 180)
Tyson
Dec 25, 2005 04:40 PM
'89 hatch
15
Jun 26, 2002 05:59 AM
