EK side mirror fitment for EG?
Old Feb 13, 2007 | 01:18 PM
B18C-Hatch's Avatar
New User
Default EK side mirror fitment for EG?
I have searched and found confusing results
I have '95 Civic CX and want to get 96-00 (2/3dr) red side mirrors, will they fit with out modification?
if so will it mater if i get power/manual
Thanks
Old Feb 13, 2007 | 01:29 PM
B18C-Hatch's Avatar
New User
anyone know about acura or prelude mirrors either?
Old Feb 13, 2007 | 01:31 PM
Kafelatte's Avatar
Default Re: EK side mirror fitment for EG? (B18C-Hatch)
i don't think they fit because if they do seller wouldn put description like "92-00 civic" instead of 92-95 and 96-00.
Old Feb 13, 2007 | 01:37 PM
B18C-Hatch's Avatar
New User
true; anyone done an install like this? How much modification is needed?
Also how about integra mirrors; they look similar but then so do all of em
Old Feb 13, 2007 | 02:01 PM
FlatBrokeHatch's Avatar
Default Re: (B18C-Hatch)
$60... Spoon replica's. Have the same look-ish to EK style mirrors for your EG.
http://www.jdmshit.com/parts/exterior/index.html
Old Feb 13, 2007 | 02:51 PM
B18C-Hatch's Avatar
New User
they are close; but I want to get OEM ones
Old Feb 13, 2007 | 03:08 PM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
You have to re drill the mounting holes to fit the ek mirrors.
Old Feb 13, 2007 | 03:13 PM
-Gambit-'s Avatar
Default Re: (98coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98coupe &raquo;</TD></TR><TR><TD CLASS="quote">You have to re drill the mounting holes to fit the ek mirrors. </TD></TR></TABLE>
Old Feb 13, 2007 | 03:15 PM
2080EK's Avatar
New User
Stock EK Mirrors are really big. I think they may not even come close to fitting with out some real work.
Old Feb 13, 2007 | 03:52 PM
B18C-Hatch's Avatar
New User
Default Re: (2080EK)
Sounds like it may be an easy install with a dremel; but then i have manual mirrors so lining up the adjustmest rod might be a pain. Anyone have actual experience with this intall?
these ones are pretty nice though:
Thanks for the replies
Old Feb 13, 2007 | 04:35 PM
SoCal EJ1's Avatar
I've seen it done once before.. It looked goofy as hell.
Old Feb 13, 2007 | 05:39 PM
Laserjock's Avatar
Default Re: (SoCal EJ1)
https://honda-tech.com/zerothread?id=1117272
this was soooo 2 yrs ago. i am now back to the EK mirrors cause i found a set of doors from pwr window coupe.
Old Feb 13, 2007 | 06:14 PM
Default Re: (Laserjock)
^^^ exacty opposite of what the original poster is looking for.
Old Feb 13, 2007 | 06:29 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (FlatBrokeHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBrokeHatch &raquo;</TD></TR><TR><TD CLASS="quote">^^^ exacty opposite of what the original poster is looking for.</TD></TR></TABLE>
True, but the same method can be applied to the opposite, it was a good write up by the way
Old Feb 13, 2007 | 07:49 PM
Laserjock's Avatar
see this box, think out side of it. if one fit, why not vice versa? he might need to drill extra holes if he uses power mirrors on a manual car. point is, 92-95 mirrors will work on 96-00 civics. or for you, 96-00 mirrors will work on 92-95 civics.
Old Feb 13, 2007 | 08:24 PM
Chill ladies...I see alot of threads where people reply answers without reading the thread carefully. So when I said that, I was under the impression that you thought he needed EG mirrors on an EK.
...also I can't help but notice how huge EK mirrors will look on an EG. I can't imagine this looking good.
Old Feb 14, 2007 | 06:39 AM
Laserjock's Avatar
k sweetness. but don't assumption
btw, i think i just got tennis elbow from shoveling snow. day off FTW
Old Feb 14, 2007 | 09:34 AM
B18C-Hatch's Avatar
New User
so it can be done and hope that the levers are in the right position.
if i find cheap ones i'll post up pics
Old Feb 14, 2007 | 11:45 AM
monicle's Avatar
yeah its fairly simple to do I have a template for redrilling holes. shoot me a pm if you need it.
you are left with a tiny gap at the top of the mirror though.
Old Feb 14, 2007 | 03:56 PM
B20_ej1's Avatar
Default Re: EK side mirror fitment for EG? (monicle)
what about integra mirrors? anyone try this?
Old Feb 14, 2007 | 04:02 PM
Laserjock's Avatar
Default Re: EK side mirror fitment for EG? (B20_ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">yeah its fairly simple to do I have a template for redrilling holes. shoot me a pm if you need it.
you are left with a tiny gap at the top of the mirror though. </TD></TR></TABLE>
i am working on a set of type R mirrors but the tip of the section that bolts to the door on the Integra mirrors comes to a point while the civic mirrors are rounded. there is still plenty of material so that i think i can radius the point to match the contour of the civic fender...too cold for that right now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20_ej1 &raquo;</TD></TR><TR><TD CLASS="quote">what about integra mirrors? anyone try this? </TD></TR></TABLE>
hondaon18's
20
Apr 18, 2010 06:13 PM
ekillah
Nov 3, 2007 02:07 PM
hale_image
Oct 31, 2005 01:31 PM
PotatoePAPA
Oct 21, 2003 10:42 PM
mckenzie
Jul 4, 2002 01:16 PM
