Headgasket dohc VTEC...3-layer mls, nitride treated...cheap!
I paid $68 for this gasket and never even opened the bag! It is from Nippon Racing, made in Japan. As the title states (and the label also) it is a multi layer steel gasket, 3 layers to be exact and is nitride treated. Very similar to the Cometic. Thickness is .040" (1mm) so for you f/i peeps it might help lower your c/r a tiny bit. The bore on it is technically 82mm so I guess it would work on stock bore or any overbore up to .040". I purchased it to use on a GSR block, don't know if that makes it any different than a B16 or ITR gasket. $40 shipped
Modified by klungemonger at 6:21 PM 2/27/2007
Charlie Moua
Oct 24, 2003 12:15 PM
