5th gen header oxygen sensor
Old Feb 13, 2007 | 12:05 PM
cooldudeness's Avatar
Default 5th gen header oxygen sensor
Hi, I have a 5th gen accord that im going to be putting headers onto. There is a big metal gaurd over the stock headers right now and I believe that I need to pull the oxygen sensor on the left out before pulling off the gaurd. Does anyone know how I get that sensor out? Do I twist and pull?
Thanks
Old Feb 13, 2007 | 12:47 PM
Tech-Nics's Avatar
if you look to the left of the o2 senor (away from the heat shield) you will see that it is plugged in, all you gotta do is unplug it, give it a good yank. not to hard though and it will unplug and you then can take off the heat sheild.
Old Feb 13, 2007 | 12:48 PM
philadd's Avatar
Default Re: 5th gen header oxygen sensor (cooldudeness)
The sensor screws in the same as a bolt would. There's a special socket for O2 sensors, which you can rent for free from AutoZone. You'll need to reinstall the O2 sensor on the new header. The big metal guard you speak of is the heat shield, which you will not be able to install with an aftermarket header.
orourkeusn
Honda Civic (2006 - 2015)
Jul 5, 2008 04:02 AM
stevenskates
Jan 8, 2008 01:14 AM
jakscivic
Aug 29, 2006 09:47 PM
f1uxx
May 8, 2003 09:45 PM
integraautox
Sep 23, 2002 01:18 AM
