D15B2 performance parts
I am looking into buying a '89 Civic Hatch with a D15B2 in it, it already has an intake, header back full exhaust, slight drop, short-throw shifter, and ignition upgrades, I was just wondering what else is out there performance wise for this engine short of doing a Swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondata151 »</TD></TR><TR><TD CLASS="quote">yup</TD></TR></TABLE>
king of the hill moment
no cams or anything that you can put in to make a little bit more power? and what kinda power gains would be seen from the MPI swap, and wheres a good place 2 get it (and average price and difficulty level)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02S-dime »</TD></TR><TR><TD CLASS="quote">no cams or anything that you can put in to make a little bit more power? and what kinda power gains would be seen from the MPI swap, and wheres a good place 2 get it (and average price and difficulty level)</TD></TR></TABLE>
Maybe you could get a custom grind cam. On the mutipoint swap I dont know how much more hp but if you never done any wiring or engine work it should be pretty hard. But once its converted to mutlipoint you could go troube easyier
Since I'm such a nice person, I'll tell you the Horsepower gain --> You can expect to be running around 102 HP (Crank), or in other terms you'll turn your boring stock DPFI motor in a boring stock D15B7 with more power out of the next generation
Tell you what man them dang ol n00bs man dunno bout no dang ol D15B2 slow'r en a dang ol slug man shoot. (Boomhauer moment). Yup.
iv read that if you put a d16a6 cam in a d15b2 you have to get a different timing belt.. not from a d16a6 but something els.. or maybe im crazy.. but anyways.. dont mess around with dpfi. swap in a mpfi (si) manifold . its day and night. plus you can drop in a better motor like a B series or dohc zc and not worry about wiring mpfi since you already did it. if you go with a b series vtec engine then all you need to wire is vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">iv read that if you put a d16a6 cam in a d15b2 you have to get a different timing belt.. </TD></TR></TABLE> No you don't, myth killed before it started
FROM WHAT I UNDERSTAND, YOU CAN USE THE D16A6 CAM GEAR WITH THE CORRESPONDING CAM(SI). IM IN THE PROCESS OF DOING THE MPFI SWAP AND THATS WHAT I WAS TOLD.
GOOD LUCK WITH YOUR PROJECT
OH YEA, YOU'LL NEED THE PM6 ECU AS WELL!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. »</TD></TR><TR><TD CLASS="quote">you have to use a different cam gear. from a y series engine, d16y8, etc...</TD></TR></TABLE> Correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rayzian »</TD></TR><TR><TD CLASS="quote">take out the secondary butterfly plate in the TB, it's held on by two screws and gives the intake a little more roar</TD></TR></TABLE>
and so it begins................
please dont take anything out of your TB. its there for a reason. plus you'll feel really stupid when you drop the screws in your intake.
ya thats what i was talking about^ thats what iv heard/read. dont know if its true.. dont really see why you wouldhave to use a different gear though..
the butterfly plate is likely there to channel air flow, the factory put it there for a reason. Not for sound, if they were to muffle sound, theyd put baffles of some kind in the intake tubes. He's right, dont touch it, who wants roar anyways if youre not going fast.
ya thats what i was talking about^ thats what iv heard/read. dont know if its true.. dont really see why you wouldhave to use a different gear though..</TD></TR></TABLE>
you won't be able to get engine timing setup properly without it, due to the b2 crank rotation/indexing being different than the a6. simple mechanics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonknee »</TD></TR><TR><TD CLASS="quote">sell your motor to a ricer and buy a better one.</TD></TR></TABLE>
