D16z6 swap Now Car wont start!!!!!!!!!!!!!!!!!!!!!!!!!
i just finished my d16z6 swap on my 88 civic hatchback and the car wont start the fuel meter says that there is no gas but i put 10 dollars in it and changed main relay but it still wont start. can anyone help me?
Spark? Fuel Pressure at Rail? Did you wire it up properly?
And read this thread here, do not come back to this thread until you read this one --> https://honda-tech.com/zerothread/1483855
little more information would be nice...as stated before <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Spark? Fuel Pressure at Rail? Did you wire it up properly?
And read this thread here, do not come back to this thread until you read this one --> https://honda-tech.com/zerothread/1483855</TD></TR></TABLE>
HT is not miracle workers
reading 0 means. no power, no ecu, ground bad, bad fuel pump or relay.
wiring can cause that if you have changed something.
what model is your car DX/STD? Maybe the resistor box is unplugged.
"HT is not miracle workers
WORD
"WORD
i did all the wiring right my 88 civic is a std and i sprayed starting fuild in the throttlebody and started really quick then turned off` 1qqqqqqqqqqqqqqqqqqqqqqqqqqw
May be something as simple as having a bad gas filler line. You could have poured 10 gallons in and it went right out on the ground. (Had that expirence once with a civic I bought, that someone had cut the filler line).
you forgot to hook up your grounds on your motor, ground your tranny with a wire and at least one wire from the valve cover to to car chasis, or from the intake manifold to the car's chassis
i mean i had that problem, does it have a wierd buzz sound when on accessory?? anyway just a suggestion let me know if that was it
i heard a buzz a while back but i have the vavle cover ground and the tranny and the thermostat housing grounded.
Did you try taking it out and checking the soldering points? Do you have all the grounds hooked up? battery hooked up? Checked all the fuses under the dash and hood? Do you hear the fuel pump priming? What ecu/distributor are you using? Did you do a visual inspection under the car, i.e. fuel lines, around gas tank area? Did you get the engine assembled of did you have to put the head on, how's your timing? do you have spark? there's so many things it could be, start looking and update us
every thing is in timing the pump is not priming and the main relay is not clicking and the ecu is p28 and the dizzy is obd1 im going crazy dont know what to do.
dude ur didn't say your running and obd1 setup.
I bet its your wiring. Check it over make sure the right wires are going to the dizzy. I have done this before wiring from std to si/mpfi has its share of wiring problems.
thespawnkiller
Dec 2, 2008 05:33 AM
