car wont start
ok i put my new motor in and pretty sure its in timing. it wont start it just keeps turing over. i got spark, conpression, and gas new performance dizzy and injecteors the only i can think of is that it is out of timing or to check to see if dizzy is sit on the #1 plug other than that i have no idea
ya i get the same thing but check these thing
Fuel pressure
fuel filter
fuel pump relay
see if you get in any juice to your fuel pump
if not hope some one else would jump in
good luck
Fuel pressure
fuel filter
fuel pump relay
good luck
Did you go over all your grounds? I have heard that problem with swaps make sure the contact for the ground is clean. Did you check to see if you have fuel? When you turn the ignition to "on" and not start you should hear a buzz of the fuel pump priming the system. You could also take out a plug and see if its covered in fuel after turning it over for a few seconds. Where did you get your motor, was it running prior to swap? give us some more to work with here. What "performance" dizzy did you put in? Unless your pushing past 450hp then i suggest you stick with stock to avoid headaches.
make sure you have the injector wires plugged up to the correct injectors. Happend to me on a h22 swap into an accord. i put the #3 wire to the #4 injector, and vise versa. It would have spark and backfire every now and then.
i got the dizzy from jc whitney i hear the fuel pump come on there is fuel on the spark pluges do u think that haveing the wrong injector in the wrong clinder will cause it not to start i still got to check fuse and check to see if the dizzy is on the #1 wire when it is in timing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-h22 »</TD></TR><TR><TD CLASS="quote">i got the dizzy from jc whitney i hear the fuel pump come on there is fuel on the spark pluges do u think that haveing the wrong injector in the wrong clinder will cause it not to start i still got to check fuse and check to see if the dizzy is on the #1 wire when it is in timing</TD></TR></TABLE>
If you have the wrong wire to the wrong injector it def will not ever start. It will be spraying fuel into the cylinder at the wrong time.
jerryscherry
13
May 8, 2014 10:08 PM
kuNGFu pANDA2o9
Jun 26, 2009 09:00 AM
bimmeracer
Jul 16, 2008 06:12 PM
