92 Gas Mileage Falling - Need Help
My gas mileage has been falling over the last year or two. I used to get about 420 to 440 miles per tank and now I get about 300-320. The sled has about 280K on it.
Timing belt is 5K old. Tires are new and car is aligned. I did new cap, plugs, wires, rotor, etc. about 15K ago.
I guess that I should look at the O2 sensor next? Is there any way that I can test this with standard equipment, or should I just get a new one? As far as I know the the O2 sensor is original.
Any other opinions or suggestions? Thanks.
can anyone make a FULL list of what we should change in order to get a better gas mileage? because im only getting 150 miles on a full tank.
+spark plugs
+spark plug wires (i might go with ngk)
+oil change
+oil filter
+air filter
+O2 sensor
+EGR (forgot what it means)
+granny driving
+distributor cap
+distributor rotors
+thermostat
what else can i add to the list so that i can make a new topic of a list for getting better mpg out of your accord?
+spark plugs
+oil change
+oil filter
+air filter
+O2 sensor
+granny driving
+distributor cap
+distributor rotors
+thermostat
Yeah. Air filter is good too. I usually buy 3 or 4 at a time and change them when I change oil.
This has been going down for 2 years and I take good care of my car. This is not a routine maint thing.
i see this exact topic on a monthly basis. do a search and make a check list from all the other post others have already replied to. factor is as your car ages, that it will deteriote production. perks of having an older car.
EvenStar
Oct 2, 2007 11:44 PM
joaodossantos
Jun 9, 2007 08:18 PM
